190 weight? |
grinder220
Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2386 |
Topic: 190 weight?Posted: 31 Aug 2026 at 10:30am |
Does anyone have a close estimate on what a 190 would weigh with no weights,cast centers removed and 18.4-38 9 bolt dual rims/tires put on. Hollow front bolster, late series 1 so it has the 3ΒΌ inch axles and heavy fenders, 3 point hitch on but could remove if needed. Looking to get down to 7300 pounds if possible without taking too much off just for a couple local pulls next year
Posted: 31 Aug 2026 at 11:13am |
Nebraska Test #887 for a 190 XT (small axles) says 7750 lbs (no driver) with 18.4 x 34 cast iron centers, 7:50 x 16 fronts, SNAP-COUPLER hitch and the old fenders. I assume 2 batteries. You can get there. I'd try to slide the lift arms off the rock shaft and drop the draft arms. I set one up 50 yrs ago (series 3) for 7500 lbs and we had 18.4 x 38's and still used the cast iron centers with zero fluid, newer fenders, one battery and a home-made steel front support. I've done a couple and I don't think this one had the home-made NF end.
