190 clutches
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: 190 clutches
    Posted: 27 Sep 2011 at 6:14pm
When i bought my 190 i was told it slipped in fourth high, it has mowed and baled 3 hay crops with no problems this summer.  now my son the operator says when it sits a few days when he starts it it won't move in any gear either high or lower, but aftwer awhile it will go fine.  Is this a hydrolic clutch and high low that could have a sticking valve or What?  he tells me the fluid level is fine and we haven't changed the filter or fluid  since we got it, so hard to tell how long the fluid has been in it.   Help/thanks  Tman
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Roger Nolin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 8:30pm
when it will not move, does he still have power steering? if not then the flow divider is sticking. I don't remember how to fix it, but remember the problem. but usually if I remember right either the hi side or the low side would work.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 9:28pm
If nothing works, the pump is loosing prime. Check all the connections between sump and pump. If all is tight front seal in pump needs replaced.   MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 10:30pm
The problem is most likely the flow divider on the pump sticking when nothing works.
Also check the linkage to make sure the valve is fully shifting for the slipage issue.
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 10:46pm
If it has the filter between the frame rail and the oil pan on the left side, I'd check that first. Rubber fittings go bad and leak and the filter gets plugged. Mine did the same thing and after cleaning the filter and replacing the rubber hose fittings, no more problems.
Edited by DaveCinIN - 27 Sep 2011 at 10:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 1:08pm
would anybody have photos or drawings of where i need to go see and can see better what to do.  I am trying to study the Agco Parts exploded drawings but get lost in all the details.  Thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 8:40am
Hey guys i have tried looking but just where is that flow divider, and is there a rebuild kit for it ??  thnaks
