185 & 200 CRANK REBUILDER
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: 185 & 200 CRANK REBUILDER
    Posted: 19 Feb 2010 at 10:51pm
HELLO
 I AM LOOKING FOR A GOOD CRANK REBUILDER FOR A 185 AND 200
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 6:54am
     I assume you are looking for someone who can "regrind" a crankshaft to accept undersized bearings?? If you can't find anyone in the Yellow pages in your phonebook, I'd suggest stopping at the nearest semi-truck repair dealership who does engine work and ask them. Warning..if you have a crankshaft journal that has had a bearing "burn out" ( or spun the brg shells) and has discolored the crank journal (black or blue) or was knocking when the engine was shut off, the crankshaft is probably junk and not worth regrinding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 9:21am
     TO Dr. ALLIS
       I AM LOOKING FOR A REBUILDER NOT A GRINDER, I HAD A CRANK REBUILT AND THEN CUT BACK TO NEW DIAMETER IT WAS AN OLD SHOP WITH AN ELDERLY OWNER WHEN HE QUIT DOING THE WORK HE SHUT THE SHOP DOWN, THE 200 CRANK HE REBUILT IS STILL RUNNING THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 9:23am
Find a good used crank.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 12:48pm
Are you talking about getting the crank welded back up, reground and rehardened back to standard spec?  I don't know anyone personally that does this, but thought I would try to help clarify.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 1:21pm
Illinois Crankshaft; they may tackle that , but a good used ones prolly cheaper
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 1:29pm
YES HURST
THAT IS WHAT I AM LOOKING FOR THANKS.
ABOUT THE OTHER COMMENTS GOOD USED CRANK, THEY MAY HAVE BEEN REBUILT AT ONE TIME,THE CRANKS I HAVE, I KNOW WHERE IT CAME FROM  THANKS FOR THE INFO.DEEPLY APPRECAITED
This page was generated in 0.130 seconds.
