180 pto
Joejack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joejack Quote  Post ReplyReply Direct Link To This Post Topic: 180 pto
    Posted: 18 Apr 2018 at 9:19am
Just got a 180 allis the pto won't disengage anyone ever had one have this problem thanks
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 9:33am
On the hydraulic PTO the clutch brake can become worn, and not hold shaft from turning.. You'll need to acquire a service manual to learn how and where to check hydraulic system pressures. IF the PTO clutch is faulty they are fairly simple to repair. Have you tried to run a pto powered implement with the tractor? Does the drag of the implement stop the shaft? IF not you may also have clutch-pack problems. Enjoy the tractor, the 170- 180- 190 -200's are some of the best AC built.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 9:58am
Welcome to the Forum, Joejack!
Where are you in Se KS?
I was born & raised over sw of Carthage and my family farmed around the area.
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joejack Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 6:00pm
Yes I had the bushing on it works good doesn't slow pto down at all when you move the lever to engage or disengage pto it moves easy feels like it is not moving anything and it moves back foward on its own. Thanks I am located by elsmore ks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joejack Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 6:01pm
I meant bushhog dang autocorrect
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 7:14pm
Not sure if this is hyd pto , if not Check the linkage from the lever to the place behind the battery box, its a combination of rods and linkage,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joejack Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 7:17pm
Thanks I checked it linkage is moving
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 7:18pm
Theres a coupler inside the Power Director that may have failed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joejack Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 8:44pm
Ok thanks that's what I was afraid of
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 8:47pm
Pin sheared in linkage going into housing or shifter broken inside.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joejack Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 6:39am
Ok thanks I will pull inspection plate on pd
sason View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sason Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 7:29am
let me know what you find i may have some spare parts and i only live up the road.
180 with a turbo and 460 loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joejack Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 12:27pm
Ok thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joejack Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 6:45pm
Going to have to get a manual is the pd inspection plate on 1970 180allis behind brake pedals with a hydraulic relief value on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 7:43pm
Yup
This page was generated in 0.067 seconds.
