180 hydraulic leak
ClayP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Topic: 180 hydraulic leak
    Posted: 17 Sep 2023 at 8:00am
Looking for advice on repairing my a/c 180 that is leaking hydraulic reservoir into transmission reservoir!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 9:15am
Split the tractor and replace the oil seals on the transmission input shaft and PTO shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 11:49am
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 6:16pm
DSeries4 would you think I could finish up my fall ground before splitting the tractor. It seems to have a little more transmission fluid than it should have and the hydraulic reservoir is just off the dip stick. Is there anyway to equalize the oil by adding more to the hydraulic reservoir? Thanks in advance!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 7:50pm
Run it in low side of PD should help. Put new piston ring seals and PD housing that ring run in when replacing seals.                     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 8:46pm
I'll give that a try Mack! Thanks!
This page was generated in 0.049 seconds.
