180 front weights help
stogel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stogel Quote  Post ReplyReply Direct Link To This Post Topic: 180 front weights help
    Posted: 30 Jan 2023 at 9:18pm
Hello all. I’ve recently bought an Allis Chalmers 180 from my wife’s family estate. It was her dad’s tractor and of course, is very sentimental. She wants me to use it periodically to ensure it doesn’t just sit in the shed, but I really need some weight on the front of it to put it to use. I’m very unfamiliar with these tractors and am unsure the best method of adding factory front weights (it’s very important to her that it remains original). Can anyone guide me to a resource for front weights? It does has a very small bolt-on weight on the front. From the little bit of research I have done, it appears as though this is a “starter weight”? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 9:31pm
If it is about 5 inches tall and 2 1/2 inches thick, that is a 75 lb weight and most often there are two of those stacked on top of each other. When there are two, they protrude out flush with the grille shell, for a total of 150 lbs. There is a 250 lb weight that can be used first, as it is 12 inches tall and wraps around the front end and then two 75 lb weights can be stacked on the front of it for a total of 400 lbs. That combo is quite common on 180 tractors. What are you lifting that causes you problems ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 9:48pm
Welcome to the forum. Get yourself some manuals, they have lots of info in there.
Can you put pictures on here.
Edited by Mikez - 30 Jan 2023 at 9:49pm
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 11:05pm
Another great place is TractorHouse on the internet. Click on tractors and forget about the horsepower. Click on your brand and model. You want to check out AC’s from 170’s - 220’s. You will see all of the different weights styles and brackets that AC had for them. Welcome.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 1:16am
go to >http://brianahart.net/weights.htm...It is also in >> Farm Equipment -Knowledge Base  section on this forum...directly below the section you posted from...You will love that 180...We have three of them...And welcome to the forum...Dale
Edited by orangereborn - 31 Jan 2023 at 1:21am
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 8:32am
What part of Illinois are you in ? I am in south central near Effingham. I have a couple starter weights and some of the block smaller weights that go on after the starter. Let me know if l can help.
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 8:45am
If you are using front end loader...check for clearances...weight  info is on this website under archival tutorials...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 4:36am
I early on could not find weights so opted to add a loader. Was really light in front with any three point equipment without something up front.
This page was generated in 0.045 seconds.
