175 temp gauge
cnafarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Topic: 175 temp gauge
    Posted: 14 Apr 2019 at 1:49pm
So I ordered a set of gauges for my 175 diesel the amp, temp, and tach gauge. When the temp gauge came it has the temp probe that screws into the block like my D17 and D19 have and I know that the gauges for 175 are electric so my question is there anyway or anywhere on this tractor where I can screw this probe into so that the gauge will work or do I have to send it back and get the correct gauge.
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 4:25pm
You could remove the electrical sending unit that's in it now and replace it with the new mechanical one. It's on the RH side of the engine up front right behind the fan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 5:19pm
I'm not sure that the old style mechanical gauge "bulb" will fit inside the Perkins engine temp sender location. Diameter of the threads too large and bulb too big/deep.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 9:31pm
x2.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 9:40am
I have install the mechanical ones in Perkins engines . need to drill and tap out where sender is now and use a adaptor .Did your gauge come with adaptor that the gauge screws into.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 11:29am
Yes it did come with an adapter. At the top of the motor where the top hose from radiator goes there’s a plug on mine that an Alan head fits. I took that plug out and the adapter screwed in perfectly to that. I believe there is plenty of space to screw the probe in. I
