175 gear reduction ?
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: 175 gear reduction ?
    Posted: 12 Oct 2026 at 9:59pm
Why did Allis slow the 175 tractors down ?
And
The later 175 tractors even had a slightly bigger diesel engine. Than the 170 diesel.
My understanding is it was done thru the final drives.
But
I am still learning...
What the story here ?
Edited by Macon Rounds - 12 Oct 2026 at 10:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 10:15pm
175-180-185's all have the heavier duty/wider bull gear final drives that are 5.85 to 1 ratio. This began in 1967 with the new model One-Eighty. The HP was 64. The weight (with fluid) was around 8,000 lbs. The rear rubber was 18.4 x 28's that are larger diameter than a 16.9 x 28. The gear ratio reduction offset the larger diameter tire so that high second gear was still "plow gear". So, in the end engineers felt that anything over that 55 HP number was going to get the stronger final drives. Remember, after the 190XT and D-21 rear end failures, they weren't taking any chances.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 10:32pm
In my arena 170/175 tractors are not a tillage tractor.
And in the rhelm of bigger tillage tractors why would you slow the 175 down.
I currently run 30" tires on my D17's and 170 tractors for hay making operations. So to speed them up. I feel like i'am sleeping on my 175...
Great technical data on the 175. Thanks Doc...
Edited by Macon Rounds - 12 Oct 2026 at 10:42pm
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 9:25am
The diesels were derated. That was a 75 horse, 2500 rpm engine in any other application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 11:45am
Another thing they did to the drive line to add strength was increase the second gear (3-5) speed about 10%. I've installed pairs of these "fast" second gears in D-17's before, and they were not only a different ratio, but they were noticeable WIDER for strength. Again, engineers knowing this, for some people around the country, was PLOW gear and needed to be strong and dependable.
