175 3 point capacity |
pdh ![]() Bronze Level ![]() Joined: 13 Sep 2009 Location: Iowa Points: 199 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Aug 2016 at 8:43pm |
How much weight is "too much" for a mounted implement on a 175 3 point? Will it handle 1250 pounds?
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
I guess it depends on how far out it hangs from the 3pt arms.
ctbowles 58 ![]() Silver Level ![]() ![]() Joined: 12 Aug 2016 Location: CLARKSVILLE MO. Points: 129 |
I had a 4 bottom 70s series plow on mine and It lifted it just fine. don't know what it weighted but I am sure it was 1000 lbs +.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22001 |
If it can pick it up, it isn't too much.
shameless (ne) ![]() Orange Level ![]() ![]() Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
I carried a fully loaded 8-row wide mounted planter on my 180 for years. handled it just fine, i'm sure there wouldn't be that much difference between the 175, and 180!
Thanks, all.
Trinity45 ![]() Orange Level Access ![]() ![]() Joined: 17 Mar 2014 Location: Kentucky Points: 1944 |
If the 180 is a 6 cyclinder there is some difference. I have a 175 no weights and a 185 no weights on front. We have a 9' cut disc mower and the 185 handles it fine but the 175 is a bit light in the front when you lift it. If I had weights it would handle it fine as far as picking it up and running it.
The lifting "power" between the two tractors ( as long as they have the same type of lift cylinders) is identical. Front end weight has to be added as needed.
My 175 has suitcase weights. I am trying to determine whether it would be enough tractor for a "fill in and re-plant" planter - 4 row 30 JD 7100.
more than enough! my 180 has one weight on it in front. but I also have a platform made to fit on the front of it, that's where I carry extra seed bags. it'll hold 8-10 bags of seed. of course as I use the seed it'll get lighter, but it never raised the front end off the ground while the planter was on it. even when the boxes were full.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
I pick up a 1700# bushhog with just suitcase weights on my early 175D. Later model needs suitcase weights and loaded 9.5L-15's to keep the front end down due to the hollow front casting required for the front mount hydraulic pump....
ALLIS EXPRESS!
This year: |
