170-175 dual pto
Josh N View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh N Quote  Post ReplyReply Direct Link To This Post Topic: 170-175 dual pto
    Posted: 13 hours 52 minutes ago at 1:00pm
Is it possible to take a dual speed pto housing off the rear end housing of 185 and bolt it on the back of a 170-175 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 39 minutes ago at 4:13pm
Yes. But you'll not have a 540/1000 RPM PTO. You'll have a 270/540 PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh N Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 56 minutes ago at 7:56pm
Ok.   Can you bolt a
185 transmission housing to a 170-175 torque tube?    I would think the transmission input shaft would be different because of the different power directors?   Now that I think about it you would have to change the gearing up in bottom of torque tube like you have to when putting a dual pto on a 190
Edited by Josh N - 6 hours 54 minutes ago at 7:58pm
