10’ wheel disc |
iron79head ![]() Bronze Level ![]() Joined: 20 Oct 2019 Location: Yale VA Points: 36 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Jan 2025 at 2:26pm |
Laid eyes on a 10’ SC wheel disc today’
Question ‘ How hard would my 45’ snort pulling this disc’ 45’ has ‘ 3 slab weights NF Inner/outer front wheel weights Rear wheel weights Sandy soil |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 52933 |
In those conditions, I'd say its a moderate load...
dr p ![]() Orange Level ![]() Joined: 24 Feb 2019 Location: new york Points: 1278 |
Depends on blades too
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2162 |
If it is a snap-coupler disk and your tractor's traction booster works, it should be perfect pair.
Leon B MO
BillinAlberta ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Saskatchewan Points: 350 |
I have a wide front WD 45 with loaded tires (16's) and our soil is all sand.I actually think the old girl pulls my 10 foot disc better than my D17.Both traction booster systems work.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 3892 |
Should just play with it.
Thanks everyonefor the response!
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 32703 |
My 180 and I get along with a 12' Massey 500 wheel disc, tank of a implement on 10" Disc Plates, cuts like no tomorrow and makes the old 180 pull down hard.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 2951 |
A WD45 and 10' disk are about a perfect match. I have boht and they work well together
Here's video of my NFE 45 pulling a 14" IH disc in the garden. 2nd gear in the garden, dirt is really mellow. If I take it out in cornstalks, 3rd gear works great.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8397 |
10ft behind a 45 should be a breeze.
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2701 |
I've got a 9' #109 SC mounted disc that I pull with my WD-45. It doesn't even know anything is behind it. You should have no problems with a 10' wheel disc.
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 943 |
WD45 should handle 10' tandem disc. Tractor will need good tires.
Farmall M & AC D17 pulled a JD RWA 12.5' W18" blades no problem in plowed grd. Duals would been nice to keep tire tracks down.
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 827 |
I pull a 13’ Allis disk with one tire filled, the other one leaked most all out.
Pulled it in plowed ground with the traction booster disengaged without a problem. |
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4639 |
The how much disc can I pull with XYZ tractor, always make me shack my head. There are so many variations of disc's. Maybe there is someone on here that could list 75% of the models AC made. Then move out the other major brands, then all the short line companies.
I have a very similar disc to the one pictured below ( 8 blade 12 inch spacing) (hopefully my copy and paste is viewable) that I am not sure if if any AC 2 wheel drive until the 7000 series would really handle. It took 70 hp crawler to really handle it ( HD 9 AC ). I also have a very lite finish disc 16 foot a 40 hp 2 wheel drive handle fine. Just saying without weight per foot and blade size not much is more than a guess. As there are discs and then there DISCS.
My brain woke up, AC built bigger than 190 before they had the 7000 series. I guess there was a 200 that one neighbor had but a Miller 12 wheel disc was all it wanted. So I was wrong again.
ac hunter ![]() Orange Level ![]() ![]() Joined: 05 Jan 2011 Location: OHIO Points: 1020 |
Just wondering if anyone on here ever had dual wheels on their WD-45. We had an 8 ft. disk that seemed like enough load for the 45 and always could see the rear tractor wheel tracks behind the disk till Dad got a set of duals on it. Much easier load after that and no wheel tracks. I think I was about 8-9 years old and went with Dad to Tractor Supply to get the rims and clamps.
Travis2766 ![]() Silver Level ![]() ![]() Joined: 26 Aug 2015 Location: Amherst, Wi Points: 415 |
I have duals on my D17 and pull a 12’ John Deere disk. Makes for lighter ground pressure hence the disk cuts in better and doesn’t leave wheel tracks, also makes for a lot smoother of a ride on rough ground. ![]() Edited by Travis2766 - 10 Jan 2025 at 6:38pm |
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
My grandfather did.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3688 |
we had duels on the wd 45 and the d17d when we did tillage work but we farmed hills that the small bales would roll to the bottom of the feild when they came out of the baler . i really tought that it was cool to have the duels on when i was a kid
I had duels on my wd45d…
I have a set of dual on my WD45. My uncle used them back in the70's and 80's to break open his muck fields. Same tractor, different duals.
Edited by Allis dave - 11 Jan 2025 at 5:51am |
I have a pair of clamp-on duals I built for the 45's but have never mounted them to a tractor. They would fit either of the 17's now too. Maybe someday????
