Will my D15II run this? |
Post Reply |
copyrite1972
Orange Level Joined: 26 Feb 2016 Location: idaho Points: 331 |
Posted: 03 Jun 2017 at 11:21pm |
Ouch!
D15 Series II
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2854 |
The buyer probably didn't have to ask his wife
copyrite1972
Nope, called 10 minutes too late......
Thanks Fellers! maybe next time
D15 Series II
JohnCO
Orange Level Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
It's no longer listed, hope you were the buyer!
Allis Express participant |
copyrite1972
Thanks for all the input Fellas! Think I'll call him (After I talk to "The Boss" about it! )
D15 Series II
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10571 |
Great mower. Only thing to watch for is when turning. Don't turn too sharp. The tongue is the weak link on them.HTH Tracy
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
If your Series Two is in reasonably good shape engine wise, it will have no issues with it.
My "tired" high hour SII SC runs a heavy 6' Bush Hog brand cutter with a A-C 3-pt. adaptor. 1st gear low or high range on the PD, in brush/native grasses sometimes above the radiator cap. 2nd low range all day long in open pastures, 2-3' tall grasses including bunch grasses. Keep it up so only cutting 3" minimum height and just touch a grinder to the blade edges occasionally and she will be fine. I have the 5" version (3-pt.) of that cutter and the clutch set-up is sweet. Just be sure to check the two pins/springs on the clutch assembly before you put it to work and check the tension nut. Kept lubed, they are tough old units.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8039 |
That one hasn't been used too hard....the sides still look flat. Worth the money.
Butch(OH)
Orange Level Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3831 |
Ohh, OK I looked at the pictures and see that. On my Bush hog the ratchet replaces the cylinder, no place for both. |
Gary Burnett
Don't need the collars on the cylinder with the set up shown the rachet assembly holds it to whatever cutting height needed. |
Butch(OH)
I am pulling a 6' BushHog 306 with my D-15II and it handles it like a boss. Can run in 3rd high unless the grass is knee high. If you need a cylinder be sure to get some depth stops for it as you will need them due to the iffy hydraulic hold on the 15. I just run the turnbuckle on mine.
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
I have a 6' cutter on my D-15 II that is used for road ditches. Lots of power.
Gary Burnett
Really good cutters,I have one I use right much.The D15 can pull it in normal cutting
situations.With reasonably sharp blades they do a good job and that's a good price on it too.The rachet adjuster on it now sets the height,a cylinder just raises it to transport it I usually don't worry about having a cylinder on mine.I rode a lot of miles growing up on a WD45 and one of those hooked to it,found mine at an auction awhile back. |
copyrite1972
This popped up on CL:
My question: Will my D15 II run it? I think it might be missing a hydraulic ram to adjust the height, but I'm good with what's on it now. Can anyone tell me anything about it? Thanks in advance!
D15 Series II
Post Reply | |
