WD45 PTO SEAL
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: WD45 PTO SEAL
    Posted: 22 Feb 2010 at 6:07pm
Can you still get this seal?
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 6:33pm
  we stock that seal   1-800-254-3116
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:16pm
I would think that you could probably take it to any bearing supplier and find a match.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:25pm
I needed a "quick fix" a few years ago, and could not find one locally as thick as the original.  Went to a bearing supply house, bought two with the correct OD and ID and installed them in tandem.  They're still running and don't leak.
Why is there never time to do it right the first time, but always time to go back and fix it?
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:29pm
Napa has them. Just give them the old one to match it up. About $3 and use 2 as mentioned before.
Yours has numbers, mine didn't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:39pm
I just bought one from my AGCO dealer, PN 70224779.   National Seal #470061.  HTH.  Mike
Edited by Skyhighballoon(MO) - 22 Feb 2010 at 7:39pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:58pm
Thanks for all the info Guy's I would like to find one just like the original if possible.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 8:11pm
  OUR STOCK IS 224779
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 8:46pm
What you have is the original seal made by Chicago Rawhide.  Chicago Rawhide was absorbed by SKF Group a couple of decades ago, and they gradually phased out the CR unique seals.  I actually found a New Old Stock CR seal of the right size a year or so ago by shopping at a local hydraulic & seal shop.
You might find some NOS AGCO or CR if you shop long & hard.  But, if Norm [Ind] has got them in stock, you are farther ahead just to have him ship one to you.
This page was generated in 0.052 seconds.
