WC 6 with bolt front hub question?
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: WC 6 with bolt front hub question?
    Posted: 23 Mar 2011 at 11:30am
Will WC 6 bolt front hubs transfer/fit onto WD-45 front axles in place of the existing 5 bolt. Can anyone tell me if it's the same and will switch??
Thanks
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 11:36am
Zyta
not a true answer but on WCs the 5 bolt ,6 bolt and spoked all inetrchange.
And have put WC 5 bolt on a WD
hope it helps
Phil
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 11:41am
Thanks Phil, I am pretty sure the hubs will interchange.. hoping some one out there mayhave tried this or might know for sure.
Jim
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 1:32pm
Agco tells me both hubs 5 and 6 bolt use the same bearings so interchange must work?
Jim
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 6:34pm
So long as the bearing spacing is about the same.
Gerald J.
