traction booster |
Post Reply | Page <12 |
Author | |||
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3299 |
the one thing the allis chalmers traction booster with the snap coupler does that the rest do not do is sense the pull on the drawbar to raise a load on a drawbar pulled implemnt
Sponsored Links | |||
Orange Level Access Joined: 12 Sep 2009 Points: 19570 |
A-C made a "Traction Booster drawbar" for 3-point hitch tractors that also did the same thing for pull-type implements. I've investigated the M-F pressure control system and it does something similar, but it is not automatic. It requires the operator to constantly move a lever increasing or decreasing the weight transfer thru the hitch. It also didn't turn very short, which the A-C 3-point system hitch did.
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2859 |
My 8760 has one lever.
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3469 |
I have the 52 plow on the 15, going to the power show this weekend. Traction booster gauge is toast on this tractor so it will be all 'seat of the pants'. Will give a report after plowing with it.
It is important to have the "rate-of drop" screw underneath the sediment bowl adjusted correctly for the best performance. You don't want the drop rate too fast or it will hunt up and down all the time. Big coil spring adjustment and this are covered in the Operators manual.
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11399 |
Good for you and your 8760. |
Kcgrain
Orange Level Joined: 24 Sep 2009 Location: Wisconsin Points: 767 |
Was that supposed to be sarcasm?
The Allis Chalmers traction booster system is the only system that actually worked, if you knew how to set it, and adjust it. NO manufacturer draft system worked as good or as fast especially John Deere whose system was pretty much non existent until electronics came into being. Your 8760 has one lever and electronic adjustment to make it work. The flaw with traction booster was the dealers not explaining to farmers how it worked and how to turn it ON. One example (of many) was my friends Dad plowing with the 8050 FWA and an Allis 4-16 semi mount plow, I argued with him there was no way an 8050 wasn't going to pull more plow than his 190XT did. His argument was their farm was heavy red clay, and to convince me he wanted me to ride with him out plowing. So I did and the plow pulled like a rock, it wasn't set completely right, so I adjusted that, and it helped but was still a rock, it finally occurred to me the traction booster wasn't on, I reached over him and turned it on and he immediately pushed in the clutch because he thought the plow had unhooked. He looked at me and said what the hell did you just do? I said the traction booster isn't on, and it is now. He went back to plowing and couldn't believe the difference " no wonder we pulled the old plow in pieces" he said a few rounds later. What he was referring to was the the 4-16 Allis plow they pulled the hitch off of twice with their 7040 before trading for the 8050, which ripped the front off the plow not long after getting the 8050. Nobody explained to them when they bought the 7040, or the 8050, and nobody stopped to ask why the 7040 was tearing the plow apart, it had the power so they just accepted it. Allis didn't design the plow to be in the ground 12"+ going through clay knolls, the plow was trying to pull the knolls down, and both the 7040 and 8050 had the steam and weight to do it, and the 8050 the traction. |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8150 |
I always thought the traction booster worked awesome on D17 snap coupler.
The spreader bar between lift latches made a distinct radial when lifting a lowering. So I always knew when the traction booster was working. I always enjoyed that.
Edited by Mikez - 04 Aug 2023 at 9:06pm |
IBWD MIke
I did not get to plow with the D-15. Did plow with the 45 however. Of course I'm used to using the T-booster on it and it worked great as usual. Dirt was like concrete, it always is at this show. I'll get the 15 to a plow day somewhere this year.
ncpackfan39
Bronze Level Joined: 31 Jan 2024 Location: Wisconsin Points: 12 |
I’m looking to replace 4 springs in the traction booster linkage on an Allis Chalmers D21. These part numbers are found In the “sensing linkage / 3-point hitch”parts manual but I can’t find a replacement through agco. Would anyone know where to find new springs for the 3-point hitch traction booster linkage?
The parts numbers are: 243449, 241479, 241618, and 243488. I appreciate if anyone has any info. |
