Tires?? |
Post Reply |
BiG210
Orange Level Joined: 13 Sep 2009 Location: ohio Points: 412 |
Posted: 12 Feb 2012 at 8:51am |
Can I run a 6ply and a 10 ply on the front of 8070 and not hurt the front u joints thay are 18.4-26's two dif. makes. also none raidel's
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22816 |
I don't know why it would hurt the U joints. Might tear up the differential if the size is much different , making it slip all the time.
farmtoybuilder
Orange Level Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1453 |
If the rolling diameter of them are the same you should be ok. But if they are different diameters then you will hurt the differential and such! Need matched set of tires on any FWA tractor!
BiG210
Thanks I thougnt that if one is 6 ply and one 10 the 6 would be softer and flex more under a hard pull. |
EricSWPA
Orange Level Joined: 12 Sep 2009 Location: PA Points: 292 |
Probally would flex a little more you could run more air in the 6 ply.
Post Reply | |
