Forum Home Forum Home > Allis Chalmers > Farm Equipment -Knowledge Base
The Little AC's, a history lesson
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: The Little AC's, a history lesson
    Posted: 02 Oct 2018 at 4:43pm
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 7:41pm
Ken in Texas  thanks CTucker for posting the correct address to  "The Little A-Cs".   Bill Long can't help but like this AC History Lesson as much as I did
GreenMule View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenMule Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 10:06pm
More good stuff to keep,thanks for sharing
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2018 at 6:00am
Great reference! However, I notice that the section on hydraulics uses the term ‘power booster’ for the weight transfer system. The correct term is ‘Traction Booster’.
Oliver Corporation used the term ‘Power Booster’ for their optional shift-on-the-go clutch on the 770 and 880 tractors.
Edited by TramwayGuy - 23 Oct 2018 at 6:02am
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2019 at 8:53am
Wow, great info
Thanks guys!
Gafry53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gafry53 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 8:38am
Just bought a Allis Chalmers B model that need governor work . The tractor bogs down when going up a hill??  Also bought a Model C that gasoline tank leaks and is a narrow front that need replace wheel slop is bad. Any help on gasoline tank leak or the Engine bogging down?? Going to due a tune up kit on B to see if that helps bogging  ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 9:15am
Welcome Glen... you posted in the Farm Equip KNOWLEDGE BASE, where we store TOPICS that come up over and over... The Post Area above Knowledge Base is FARM EQUIPMENT .... You will get a LOT more answers in that area.
Some with a small gas leak have removed the tank, cleaned and put JB WELD over the area..  Others have used a couple layers of fiberglass to patch.. Engine bogging down could be governor if it is not working.. Could also be timing or loss or gas in carb... Go to the FARM EQUIP area and start a post.  Others will explain how to set the governor and test.
kenbow56 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbow56 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2022 at 7:24pm
CTucker   Thank You for the Little C's link, great info. most interesting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2024 at 6:25am
I may have missed this on the little Allis History
 Bs rear rims and clamps on 38 Bs were split rims.   Cast iron clamps  for the split rims
Only were used.
 In 39 B rims  were made by firestone using Cast iron clamps for these rims.  Clamps  fit over and behind 4 tabs mounted  to the bottom of the tire beads on these rims. The clamps used 1/2 inch excentric bolts.
Sometime after 39 Clamps that fit over 4 bump using 3/8 bolts . Two plain , two excentric to the end of B production
      I need to learn how to post pictures.
B front wheels evolved to. From cast iron  38 wheel center to 39 stamped centers riveted to then to conventional 5 hole front rims.
     Hope this helps to restore early Bs back like they were when new.    Good luck finding old B parts.
     Early Bs also had single rib front  tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2024 at 6:28am
B tire and wheel changes early in production
This page was generated in 0.075 seconds.
