Swather or Disc mower |
Post Reply |
Gregor
Silver Level Joined: 11 Sep 2009 Location: Prague, Ne Points: 305 |
Posted: 15 Aug 2012 at 8:33pm |
My swather is shot and looking at getting a different pull type swing tongue. I started looking at the 3 point disc mowers also. I've never been around one. Any recommendations on either. Is there any brands to stay away from. I have around 10 acres of alfalfa and also mow some brome waterways. We rake the wind rows together, so would be raking either way. I currently use a sickle mower for the brome. Thanks
AMB(wcIL)
Silver Level Joined: 03 Oct 2009 Location: Chapin Il Points: 292 |
Disc mowers are great for mowing, you'll never use a sickle mower agian. Kuhn makes JD and new hollands. I like our 275 JD, but it takes a good size tractor set out wide to ballance the load hanging out there. At least on our hills. Andy
WC7610
Orange Level Joined: 11 Sep 2009 Location: Sioux City, IA Points: 764 |
Ditto on above. Once you use a disc mower, you will never go back to a sickle
Thanks
Most Bad Government has grown out of Too Much Government- Thomas Jefferson |
Michael (WI)
Orange Level Joined: 12 Sep 2009 Location: Larrabee, WI Points: 811 |
Discbines certainly are nice. If you miss a sliver or are cutting a wedge you can re-run a row without clogging guards. Also in downed hay they seem to lift it and cut it when otherwise it would just lay under the guard. The only downside I have found so far is they demand horsepower. Normaly I cut with a 9' AC haybine and the 185 doesn't even know it is back there. When I borrow a 10' New Holland discbine it knows. Flat land I can cut in 6th no problem, but on our big hill I have to go down to 3rd to hold rpm's. Edited by Michael (WI) - 15 Aug 2012 at 10:20pm |
JohnCO
Orange Level Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
I bought a new Hesston 1345 12' hydro swing disk cutter several years ago, best investment in haying equipment I've ever made.
My cousin in Ohio has had two New Idea 9' diskbines. He mostly runs JD but likes the New Idea better then the green ones, say's they are quieter. He bought the first diskbine maybe 15 years ago. Had a field of grass hay 6' tall that had fallen down. His NH haybine would cut for 20 feet and plug up. He called the dealer to bring out the diskbine and after making two rounds at 5 MPH, told the salesman he'd take it. Edited by JohnCO - 15 Aug 2012 at 11:45pm |
Allis Express participant |
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50756 |
Try a Drum mower, it has less moving parts than a disc, and costs way less. Google Carter equipment, Tennessee. My 5-1/2' drum mower was about $3K, 4yrs ago.
bill2260
Silver Level Joined: 30 Mar 2010 Points: 215 |
I have a nh617 9 ft disc mower that I operate with 185. Mows about 200 acres of hay and pasture a year. I love it. Tractor handles it well mowing. Transporting you need to use your noggin. It is heavy. Do not raise or lower with the mower pointing it down hill. I mow in second hi. Would go faster, but ground hog holes or blow holes are hard on my systm. Not worth it. Bill
Post Reply | |
