sunstar 20 driveshaft |
Post Reply |
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2226 |
Posted: 20 Aug 2020 at 11:23am |
Need to remove engine to replace dead ignition module and cant see how to get the driveshaft undone---looks like solid shaft and cant get to or even see the engine end --oil cooler in the way and all that tin around it. Anybody ever take the engine out of one of these? --I had the engine out of my 917-h but no oil cooler in the way on it.
im4racin
Orange Level Joined: 12 Jun 2017 Location: Garrison ND Points: 847 |
Thanks(1)
Had many out. Do not remove the coupler from hydro input or you will have a nasty vibration. There is a removable cover from the bottom side. Remove it and the 4 socket head bolts that attach the flange to the flywheel. Lift engine out.
If you do want to slide shaft and all out with the engine then the cover is the only thing to remove but if you don’t get the splines lined up correctly on installation it will have a vibration. Some of the vibration can be cured with a new yoke on that end. They are available from simplicity for about $100 |
ac fleet
Found the plate--one screw holds mine on ---flange bolts on this one are 9/16" ---- didnt want to take whole shaft out so will hit the bolts with the big impact and let the shaft hang! --- I didnt see the little plate----was lookin on the wrong side and as always, in a hurry! lol! Thanks for the reply!
Post Reply | |
