Spray for garden?? |
Post Reply |
Author | |||||
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
Posted: 25 Feb 2024 at 10:19am |
Crazy question, is there a spray to control weeds in a garden that wont hurt plants? Kinda sounds off to use spray with things a person will eat , but just curios; I may have to shine up the old hoe !
Sponsored Links | |||||
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4388 |
Black plastic works well in cucumbers, peppers, squash, tomatoes, etc., that are planted in hills or transplanted as plants.
After emergence, I have used Preen. Preen prevents emergence, so make sure your plants are up before using. Preen is not a spray. It is granules that you spread by hand.
Edited by WF owner - 25 Feb 2024 at 10:29am |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21466 |
what is a 'weed' ? some 'weeds' hate 2-4d, if you can buy it........ heavy layer of mulch ( NOT black walnut !!!! ) works well
dkattau
Silver Level Joined: 20 Mar 2011 Location: Nebraska Points: 249 |
PREEN works good as a pre-emerge herbicide.
dkattau
You won’t have a tomato left if you use 2,4-D. |
WF owner
...or any other "broadleaf". Grasses should grow well!!!
Edited by WF owner - 25 Feb 2024 at 3:18pm |
jaybmiller
I can't buy 2-4d, guv law...unless I'm a golfcourse........
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50529 |
Only if you get the 2, 4-D on the tomatoes. It has no soil activity, unlike the other broadleaf herbicides. If the tomatoes are small enough to fit under a 5 gallon bucket (as a shield), then you can spray most any non soil active weed killer, and not kill the shielded plant. Just wait till the spray dries, then remove the bucket(s), and you're done. You will still have to hand weed around the desirable plants...
dkattau
2,4-D drifts. It doesn’t need to sprayed directly on tomatoes to kill them. |
WF owner
In any case, Preen works well for all transplanted plants.
DiyDave
Not when there is a bucket covering the plant, till the spray has dried...
WF owner
I haven't used 2-4D for years and never used it near something that I didn't want to control weeds in, but IIRC, 2-4D is not a "contact" herbicide (like Roundup), so wouldn't there be some migration in the soil? How would you know how close you could apply 2-4D?
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4351 |
In theory 2-4D can drift just like Banviel or the newer formulations for GM soybeans and cotton. I have sprayed a lot of 2-4D over the years and never seen it drift, just lots of little skips where I could have used a bit of drift.
From what I read Banvel can volatilizes as much as 2 or 3 days after the spraying, again I have not witnessed it myself. But much harder to keep in one place than 2-4D is. Even here in Chinese colony of California there is a watered down form of 2-4D you could even find in the Walmart garden section. Well I was told Wally had it have not been in one in years. But I know the local farm supply places have it yet. Being systemic action chemical and soil activity are not the same thing. But I don't know about 2-4D if could have a very limited soil activity, but nothing that last for more than a week or 2 for sure.
DiyDave
To a certain extent all oil based herbicides can volatize. Volatility can be decreased by not spraying periods of high temperature. Spray in the early morning or late evening, with the desirable plants covered with a bucket or plastic cover. Remove the buckets or cover after spray has dried. If you leave covered too long in the sun, you risk sun burn or over heating. I would not spray after temps start hitting 55 degrees at night.
Roundup is a better choice after early spring, it also has little if any soil activity. Best is Preen or a similar pre-emergent, BEFORE the weeds sprout.
Post Reply | |
