Rebuild transmission housing? |
Post Reply |
Daehler
Orange Level Access Joined: 23 Nov 2010 Location: Lexington MO Points: 1153 |
Posted: 12 Jan 2012 at 4:48pm |
Is it possible to rebuild a transmission housing out of a 8070 FWA? The hole where the main shaft is wore pretty bad, my dads thinks it can be rebuilt cheap, I dont. Any opinions?
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77939 |
Im not familair with that case, but anything can be built up by welding and remachined, or bored oversize and sleeved back to original size.
Chris/CT
Orange Level Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
How cheap??? Ask him how much he thinks for machine work to fix housing, please post the amount here, I'm curious to what he's thinking.
Daehler
A $1,000 or so, if it can be redone.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
If you have a flat surface to locate on, another surface to square off from and enough of the bore left to find the original centerline, you could probably get it done for that.
Chris/CT
That estimate seems reasonable, now finding a good shop to do the work? Have you tried locating a good used housing? That is easier said then done I realize.GL.
MACK
I have rebuilt some of them PS housings. It takes atleast 500.00 to repair the housing. MACK
Daehler
We already put a used housing on the tractor, I think its a waist having the tihing sit around taking up space but hate seeing it go to china since they probably dont make it anymore.
Post Reply | |
