AC D14 W/LOADER
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=144727
Printed Date: 25 Apr 2024 at 10:44am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: AC D14 W/LOADER
Posted By: RUBYD14
Subject: AC D14 W/LOADER
Date Posted: 23 Nov 2017 at 2:11pm
I Have an issue with rims breaking. I cant find a HD Wheel for my front that can handle the weight of a full bucket. Any Ideas lug pattern 5 on 5 16" rim my tires are 7.50/r16. I cant get a image to upload.
Posted By: jaybmiller
Date Posted: 23 Nov 2017 at 3:01pm
are you turning the wheels standing still ? friend's D-14 blew BOTH rims off from NOT moving while turning... do it standing still with a load and man that's a LOT of stress so someting has to give. If you have power steering ,it's easy to forget about that 'mimor' detail. If you can find HD rims(they are made....) have a machine shop make some 'disks' from 1/8" plate, holes to match studs and center then weld onto rim.Ideally on both inside and outside of rim. HAS to be welded to the 'ring' of the rim NOT the original disk.
------------- 3 D-14s,A-C forklift, B-112 Kubota BX23S lil' TOOT( The Other Orange Tractor)
Posted By: LaJaMe
Date Posted: 23 Nov 2017 at 5:51pm
We have a loader on a d17 that was breaking out the bolt holes. We had the wheels turned out for more width. Turned the wheels back in and have had no problems since. We use it to load 1000lb round bales.
Posted By: RUBYD14
Date Posted: 23 Nov 2017 at 9:43pm
thanks for the info. I have not been turning without moving. I have power steering but the pump is out so you cant even if you wanted to. I did just lay new creases for my future peach orchard and going in reverse getting into the next row was tough on the arms but the bucket was empty. The original rim that was on the tractor when i bought it blew out on me. I purchased a new replacement from steiner online and it last 3 days of using the tractor. (blew out when I was moving a pile of dirt. full buckets of dirt and rock.) The loader is a ford loader that a previous owner installed. From teh picture I have seen it is twice the size of a AC loader. Is it possible to run a truck rim as a affordable replacement. will the lug bolt holes be the same. I want HD function this tractor is used not looked at.
Posted By: DiyDave
Date Posted: 24 Nov 2017 at 5:22am
need to find a wfe, from a I-60 or I-600. I think the wfe from such will bolt right up. Also, I think old Buick rims have the right bolt circle, IIRR...
Posted By: Gary
Date Posted: 24 Nov 2017 at 5:55am
From what you are trying to do - using another brand loader that is twice the size of an Allis Loader, and moving bucket fulls of dirt and rock - you are lucky just a wheel broke and not an axle spindle.
Get stronger rims and an axle WILL be next.
Sounds like you need a Track Loader, and not a Farm Tractor.
Gary
Posted By: john(MI)
Date Posted: 24 Nov 2017 at 6:48am
I think the only full width bucket they put on a D14 was for moving snow. I agree with above, you are going to end up with a pile of scrap metal if you keep pushing a 60 year old tractor that hard. What you need is a D17 for what you are expecting from the 14, and probably a Series 4 as well.
------------- D14, D17, 5020, 612H, CASE 446
Posted By: Gary
Date Posted: 24 Nov 2017 at 10:13am
John
The 414 and 415 model loaders with the hydraulic bucket has a 60" bucket.
But you get a bucket full of topsoil and you definitely have a lot of weight.
I know, I did a lot of it this summer with my D-15 II.
Gary
Posted By: RUBYD14
Date Posted: 24 Nov 2017 at 12:53pm
can you say that again but define wfe i-60n and i-600 means
Posted By: RUBYD14
Date Posted: 24 Nov 2017 at 1:17pm
I wish I could upload a photo of this any suggestions
Date Posted: 24 Nov 2017 at 1:53pm
wfe = Wide Front End IIRR + If I Recall Rightly I-60 = Industrial D-14/15, a beefer version, stronger frontend
'Milton' here has a 72" bucket( 1/2 yard), lifts 1,000# pumpkins up OK but I wouldn't 'haul' full load of heavy dirt or gravel with it....unless on flat ground. Bumpy land = shocks = busted parts = $$$$$$$$$$ !!!!
Posted By: Hubert (Ga)engine7
Date Posted: 24 Nov 2017 at 2:02pm
Go to the Forum Help section on this site and there is a discussion thread on posting pictures. Charlie Tucker has posted some good instructions on posting a picture directly to this site. HTH
------------- Just an old country boy saved by the grace of God.
Posted By: Gary
Date Posted: 24 Nov 2017 at 4:32pm
This may help, a picture is worth a thousand words.
Link to ebay 'Allis Manual for a Model I-60
Note the Heavy Duty front axle.
Gary
https://www.ebay.ca/itm/Original-1960-Allis-Chalmers-I-60-Industrial-Tractor-Operators-Manual/252853607410?hash=item3adf3fdbf2:g:2MQAAOSwpP9Y5DU6" rel="nofollow - https://www.ebay.ca/itm/Original-1960-Allis-Chalmers-I-60-Industrial-Tractor-Operators-Manual/252853607410?hash=item3adf3fdbf2:g:2MQAAOSwpP9Y5DU6
Posted By: CTuckerNWIL
Date Posted: 24 Nov 2017 at 8:22pm
IMO, get a smaller bucket, or don't fill it up all the way. Tearing up rims is a good sign you are over-working the entire steering mechanism.
------------- http://www.ae-ta.com" rel="nofollow - http://www.ae-ta.com Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF
Posted By: Eldon (WA)
Date Posted: 25 Nov 2017 at 12:22pm
Gary
I'm pretty sure the I-60/600 has hydrostatic steering, you would also need the pump, tank, steering column....basically the whole front of the tractor less the engine....heck, might as well get an I-60/600...it will probably have the reverser, too!
------------- ALLIS EXPRESS! This year:
Posted By: DSeries4
Date Posted: 26 Nov 2017 at 9:06am
Exactly! If the loader is twice as big as it should be, only put half as much stuff in it. The loader must be sized to the tractor. Not whatever someone had laying around.
------------- '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '61 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '84 8030, '85 6080
Posted By: RUBYD14
Date Posted: 26 Nov 2017 at 11:35am
I feel like something else is going on with the front as only the left rim is breaking the right one is still good. I have broke 2 on left side. Thank you all for the helpful information I will hopefully get a picture up today.
Date Posted: 26 Nov 2017 at 12:01pm
I'd check for bad/loose tierod end, wheel bearings, spindle bearings. Raise and securely block front of tractor off ground and do the 'wiggle' test on both sides. Compare left(bad) versus right(good). If anything is loose, it should be obvious.
Jay
