Power Steering Fluid
JOENJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOENJ Quote  Post ReplyReply Direct Link To This Post Topic: Power Steering Fluid
    Posted: 17 Mar 2024 at 12:53pm
I just had a AC 160 given to me. It sat for 10 years in a barn. I got it running, but the power steering is empty of fluid. I don't have a manual for it. does anyone know what type fluid is recommended?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 12:58pm
you can use ATF trans fluid ( type A or F) , or Universal Hydraulic fluid  (UTF) .... I would not use the NEW Mercons or DExtrons that are synthetic with lots of detergents... 10 wt hydraulic oil is also OK.
Edited by steve(ill) - 17 Mar 2024 at 12:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOENJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 1:04pm
Thank you Steve. I though ATF would work. The local parts store recommended power steering fluid like used in cars. but he was not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 1:07pm
that is also fine... its just a real thin 10 wt hydraulic fluid..
This page was generated in 0.032 seconds.
