Pistons |
Post Reply |
Ol case mike
Bronze Level Joined: 24 Dec 2022 Location: Michigan Points: 10 |
Posted: 23 Apr 2024 at 1:21pm |
Is there enough room to install wd 4-1/8 power crater pistons onto a gleaner z these are not wd45 power crater pistons I know sp46 need to be machined some to clear I was just wondering about the power craters
Orange Level Access Joined: 12 Sep 2009 Points: 20169 |
M & W piston kit SP-46 fits the 4 inch stroke WC/WD engines and have a Power Crater type bowl in them. If you install them in a WD45 or D-17 engine with the 4 1/2" stroke you need to machine .170" off the top so they don't smack the cylinder head. As far as what you're wanting to use, I have no idea what the compression distance/height is. Might work. Might not.
Ol case mike
I have both sets MW 4-1/8
And the smooth bowl I thought them was called power crater that is also 4-1/8 set I was thinking about putting the smooth bowl into a gleaner z code I don’t know either pin height both are still in motors with wd cranks I was just wondering if the smooth bore needed any machine work to be installed like the sp46 piston needs it’s for a unstyled wc pulling tractor that has a stock z gleaner |
In the "KNOWLEDGE" section of this website, down near the bottom of page 1, you will find "Compression ratio calculator for 226 engines".....good info for you.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3482 |
got ross duplicating some sp46 pistons (should be done any day now )for me as we speak thanks to steve fischer getting me a piston they are going in my d17 series 4 engine
HudCo
they will be a two ring piston and lighten alittle bit
And .170" shorter ??
HudCo
no i decided to leave them the same pin to top hieght, and mill them at the machine shop
Post Reply | |
