Oil type for trans. & finals on HD6E
drtdmn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtdmn Quote  Post ReplyReply Direct Link To This Post Topic: Oil type for trans. & finals on HD6E
    Posted: 08 Nov 2012 at 3:27pm
Can anyone tell me what type oil is used in the transmission and the final drives of a 1959HD6E? I believe its 90W but i dont know if that is mineral or gear?
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2012 at 4:25pm
You need 80-90w oil gear for transmission and final drive
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtdmn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2012 at 5:31pm
Thank's and That would be straight 80-90 and not mineral?
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2012 at 4:11pm
The operators manual says SAE 50W above 32 degrees and SAE 30W below 32. 90 wt EP oil is a good choise and works well. I am presently using a universal transmission/hydraulic oil because it is less expensive and the HD6's take a lot of oil. In my opinion it is very important to completely drain the old oil because these old machines collect a lot of dirt and condensation. I found a lot of water in my final drive and hydraulic system.
