no spark |
Post Reply |
wildbill26
Orange Level Joined: 25 Sep 2010 Location: claysville,PA Points: 534 |
Posted: 19 Jan 2014 at 2:47am |
ok this may be long winded but here goes. i have a b 12 that has no spark, was that way when i got it, so i put a new coil, plug, points and condencer in it. i also hard wired it insted of using the insilated lug, i cleaned up the magnets on the flywheel set both points and coil gaps per manual put it back together and still nothing, i did disconect the key switch( if i rember it just grounds it to kill spark) and still nothing, so i pulled the motor again to check the coil gap, and noticed this time there was writing on the coil that you could hardly read that said this side out, so i thought mabey i had it on wrong so i switched it around and still nothing, so im stumped. so anyone have any thoughts or sugestions? i have thought now about going to an external coil but will have to resurch that, thanks
1950 wd wide front w loader
1940 b, 1939 m crawler |
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2534 |
I've read more than once of a new condenser being bad out of the box. Might also want to roll the engine over and make sure the point plunger is moving. Another option would be a Nova or Mega Fire solid state setup. Around $12 on eBay and no more points. You can mount it in the points box and no one will ever know. I suppose it's possible your coil or plug wire is bad too.
AaronSEIA |
littlemarv
Orange Level Joined: 10 Jun 2013 Location: Wisconsin Points: 1826 |
Once when I installed the points I got the retainer for the plunger boot out of place and it grounded the points, so no spark.
Something to keep in mind.......
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
wildbill26
little marve i will check that, aaron its one of those mag coils with the plug wire built into it,the plunger is working, how dose the solid state setup work? do you still need an external coil? thanks
Edited by wildbill26 - 19 Jan 2014 at 9:49am |
wildbill26
i found the mega fire on ebay i see how it works now
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3308 |
did you get any thing oily onthe points surface what part # mag did you use
Post Reply | |
