Is this an all crop 90?
Mike4481 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike4481 Quote  Post ReplyReply Direct Link To This Post Topic: Is this an all crop 90?
    Posted: 18 May 2016 at 6:38pm
just got this home , wondering if it was a 90, need to get a. Manual as I have no clue how to run it and when I turn on pto only unloading auger works
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 6:43pm
Yes, that is a 90. It sounds like the separator just isn't engaged. There should be a lever by the tongue end to pull/push to engage it. Only shift when the Pto is stopped completely, although if the gears don't mesh right away, you may have to turn the pto a quarter turn or so.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 6:44pm
I see a auger in the grain table so it has to either be a 90 or 72, get your tape out and measure the cutter bar. I think the 90 will measure about 84" and with the gathers they call it a 90. It looks like a 90 to me.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 7:03pm
Based only on that one picture it looks like you have a really nice 90!!! Post more pictures if you can. Ryan
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 10:12pm
It's a 90and it looks like an early one since it doesn't have the "hump" on top behind the cylinder which had a comb that let the grain through to the back which went down to the grain drag. The comb directed the straw down to the rack.
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 8:00am
Should be a shifter on gear box under grain bin.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 8:22am
Shifter is up by the operator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike4481 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 3:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike4481 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 3:39pm
I got it for 200.00 needs new wood on the reel and some tlc
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 3:43pm
Make sure everything turns before putting it all in gear and grease it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike4481 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 3:52pm
Well I tried to get more pics but it says I already tried using that image or something won't let me upload anymore sorry
This page was generated in 0.016 seconds.
