HD6E Correct transmission & Final Drive Oil |
Post Reply |
drtdmn
Bronze Level Joined: 03 Nov 2012 Points: 12 |
Posted: 20 Nov 2012 at 4:33pm |
Can anybody tell me the correct oil to use in the transmission & Final Drives of a 1959 HD6E. I have heard various oils to use including 80-90wt. gear oil, 30wt. motor oil, 85-140 wt. gear oil, what is recomended.???
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29589 |
Might be time to invest in a service manual. My 7G at least had a lubricant chart on the steering filter cover so I knew where to start.
My finals take 80/90, the same should be in yours, my trans/bevel gear takes Type A ATF(using Dexron), I believe yours will use 50wt motor oil.
Edited by DMiller - 20 Nov 2012 at 4:48pm |
drtdmn
Thanks DMiller, i had forgotten about the 50wt. in the trans. your absolutely correct!
Post Reply | |
