HD6 G Radiator Cap
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: HD6 G Radiator Cap
    Posted: 06 Jul 2012 at 3:50pm
Hey Guys:  Does anyone have a good part number for an Allis Chalmers HD6 G radiator cap.  Mine is missing?
Thanks in advance for any input.  Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 4:59pm
Ok - one more question has anyone recently replaced their Needle Bearings on the Steering clutch lever.  Book shows Part No. 051513.  I made up a bronze insert to fill the void temporarily but would like to replace the bearing which was toast.
If someone has a cross reference number to Timken or National that would be of Great Help. Thank- you Orangeman!
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 6:56pm
I check tomorrow if am still have these bearings
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 12:16pm
I should have 12 bearings for stering cluch lever
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 2:56pm
i replaced the bearing with a bushing and grease fitting because the shaft was rough for a bearing. works great. also made new handles from aluminum round stock as the originals are hard to find.
dav68camaro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dav68camaro Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 10:02pm
Radiator cap # 70092028 after sn 6883 and minnpar has 3 in stock as i just ordered one for my loader $8.54 plus shipping
This page was generated in 0.035 seconds.
