HD11 track dimensions |
| Author | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
James Coons
Topic: HD11 track dimensionsPosted: 03 Jan 2016 at 10:35pm |
Are there any resources out there still that give you the dimensions of the undercarriage components (chain, pins, rollers, idler etc.) for AC crawlers? I'm looking specifically for the dimensions on HD11 chain but it would be great to have others for future reference.
| Sponsored Links | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 04 Jan 2016 at 4:54am |
here is some info I found on the net and saved on my computer
Edited by CAL(KS) - 04 Jan 2016 at 5:02am |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34862 |
Posted: 04 Jan 2016 at 7:28pm |
HD7G(as I own) and HD11 share a size of rail 7" pitch similar to IHC/Dresser older units and is unavailable anymore, a few here have upgraded bottom rollers and sprockets to use Cat rails with decent results.
James Coons
Posted: 13 Jan 2016 at 10:11am |
Does anyone know what the rail height was new?
gemdozer
Posted: 13 Jan 2016 at 11:14am |
The HD11 rail height when new are 4.062
DMiller
Posted: 13 Jan 2016 at 3:29pm |
I will try to copy that page from my references on the 7G as to rollers, idler, etc. may be a few days.
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1003 |
Posted: 13 Jan 2016 at 4:09pm |
Cal(Ks)
Why would some of those Allis specs have the same number for 50% and 75% wear? |
CAL(KS)
Posted: 13 Jan 2016 at 4:19pm |
interesting. i hadnt noticed. the inch measurements change but the MM dont? perhaps i made a copying error.
Edited by CAL(KS) - 13 Jan 2016 at 4:19pm |
Ian Beale
Posted: 13 Jan 2016 at 8:42pm |
Cal(Ks)
Mightn't have been you There is an inch/metric screw up in the FA 10 genuine manual I have in Fig 373 "Tilt angle in relation to tie rod length adjustment" in the tie rod mid position diagram. The length fully extended is 3 feet 1 1/2 inches. In the mid position it is 3 feet 3 inches. |
Ian Beale
Posted: 14 Jan 2016 at 2:46am |
And following up from the other track post.
I have usually worked on the best defence is usually offence. So I bit the bullet and put a tape on our FA 10 tracks. And had several more beers. With around 2000 hours on them 711 mm. 75% is 718 mm. The case hardened dozer fixed who pointed me on the replacements said ITM NOT Berco. YMMV - I'm only reporting! |
James Coons
Posted: 14 Jan 2016 at 11:32am |
Checked the serial number oh my machine its HD11EP 13621. Am I correct in thinking that undercarriage parts from an HD11B 5315 are different?
AC Mel
Posted: 14 Jan 2016 at 12:19pm |
YES, They should be different. I'll scan the other track specs and get it to your regular email when I have a couple of minutes.
AC Mel
Posted: 14 Jan 2016 at 12:58pm |
Ok, this should be what everyone wants to know. This is a picture of a picture
Lazyts
Posted: 17 Jan 2016 at 6:18pm |
New rail height for HD11EP is 4.25". Caterpillar says to install Cat D5 rails, with cat sprocket, rollers and idlers should fit, has been discussed before on this forum. I have looked at HD11s with cat rails installed- looks factory, and can be run with Allis sprockets as well. Most new D5 rails now measure a healthy 4.38" or so. Pitch is slightly shorter than HD11, but bushing is smaller, so still fits in sprocket. At one time Cat offered D5 bottom rollers with no holes in the end collars, so you could drill your own to fit, not sure if they are still available. (was supposed to work on 10 F/A, adapter plate needed for HD11)
Collar numbers 6T7334 and 6T7332 |
boyd
Joined: 03 Oct 2016 Location: Charlotte,N.C. Points: 4 |
Posted: 04 Oct 2016 at 6:55am |
I knew i didn't know anything but i didn't know how much i didn't know. Thanks a lot for all the information. A guy has to start somewhere. We have used old logging equipment and got the job done but that was before the 'modern era". I want to stay away from the machines with all the electronics definitely.
DMiller
Posted: 04 Oct 2016 at 11:49am |
I just got the call from a friend that scraps Heavy Equipment, got a burned 953 with at least 70% rails and shoes, he is offering to me cheap so once I get the time he is going to hold for me. I still have a set of 7G rails at my barn just no shoes to go with them. One way or another my old machine will get new dance floor equipment as the old slick shoes and snaky pins/bushings are killing me when I go to use it!!
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 04 Oct 2016 at 7:28pm |
nice find! those 953 tracks will be sealed and lubricated also. what ever it takes to keep them running!
DMiller
Posted: 05 Oct 2016 at 2:11pm |
I am only hoping!!
Tennessee Plowboy
Joined: 19 Aug 2015 Location: Auckland NZ Points: 8 |
Posted: 10 Nov 2016 at 7:08am |
I'm new to this stuff. can someone say if a near new track group taken off a D6C cat will adapt to fit a HD11E. Am I reading it right the cat has 6.75 pitch. Thanks
gemdozer
Posted: 10 Nov 2016 at 1:49pm |
The D6C track are 8" pitch and not fitt on HD11
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4792 |
Posted: 10 Nov 2016 at 4:54pm |
crawford farms
Posted: 08 Sep 2021 at 8:10am |
i am looking for rail links for a HD11EC the casting numbers i am looking for is 078701 and 078702 can someone point me in the right direction please?
