h3 |
Post Reply |
lost in h3
Bronze Level Joined: 06 May 2023 Location: missouri Points: 71 |
Posted: 10 May 2024 at 11:12pm |
well folks got the h3 running without back firing, missing, governor surging etc.etc.
now the problem is no rpm's. it runs smooth and idles great but i just can't get greater than about 1700 tops. no binding on leakage and carburetor is good. i have the governor i think correctly but just not getting the rpm's it needs at high idle or under load. thank you
TramwayGuy
Orange Level Access Joined: 19 Jan 2010 Location: Northern NY Points: 11290 |
Rated RPM was 1650. Nebraska test showed maximum RPM of 1806. You’re not far off. Perhaps you need a stronger spring on the governor.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78316 |
grab the governor rod by the spring and try to move it further open.. see if the carburetor rod / arm is fully stroked.... like mentioned, this may be normal.
Post Reply | |
