h3 fuel tank |
Post Reply |
orange80
Bronze Level Joined: 18 Mar 2024 Location: dubois pa Points: 2 |
Posted: 18 Mar 2024 at 3:35pm |
hi everyone im new here just picked up a h3 crawler that needs a fuel tank i was told h3 was based off d14 and d15 tractor i was curious if anyone could confirm if a tank off a d14 or 15 would fit my h3 thanks, eric
Eric B
Orange Level Joined: 09 Feb 2012 Location: British Columbi Points: 888 |
The D15 tank would be the right fit. A D14 tank may work but is narrower than the D15 tank and would not match up the the hood panels.
AMB(wcIL)
Silver Level Joined: 03 Oct 2009 Location: Chapin Il Points: 292 |
A dozer tank has a tube at the bottom sucking from the center of the tank to the sediment bowel in the corner. Yes a D15 tank will fit and work, but you might run out of fuel on a steep hill side. We have a H3 and I can see the tube in the bottom of Our tank. Andy
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4427 |
I have a good D15 tank available here in Maryland, very near Gettysburg, PA. PM me for details.
If you can't make it GO... make it SHINY |
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 1803 |
[QUOTE=AMB(wcIL)]A dozer tank has a tube at the bottom sucking from the center of the tank to the sediment bowel in the corner. Yes a D15 tank will fit and work, but you might run out of fuel on a steep hill side. We have a H3 and I can see the tube in the bottom of Our tank. Andy[/QUOTE Had that problem on an older JI Case dozer using a farm tractor tank. I silver soldered the tube into the center of the replacement tank and it discharged to a remote mounted sediment bowl and filter. Not original but worked well.
A career built on repairing and improving engineering design deficiencies, shortcomings, and failures over 50 years now.
Post Reply | |
