tractor decal removal |
Post Reply |
Dale
Silver Level Joined: 11 Sep 2009 Location: Ontario Points: 372 |
Posted: 26 Apr 2017 at 9:06am |
Want to remove the worn and partly missing front hood decals on my 4w-305. The decals are the banner type along bottom of hood front to back. Tried a razor blade scraper but not so good. Have new ones and putting new over old somehow does sound like a good idea.
Any advice appreciated |
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3267 |
heat gun and 3m decal and adhesive remover for the glue that stays on the paint
Stan R
Orange Level Access Joined: 03 Dec 2009 Location: MA Points: 943 |
Heat gun and razor and follow up with acetone for glue removal is what i would try
Kcgrain
Orange Level Joined: 24 Sep 2009 Location: Wisconsin Points: 767 |
Go to a automotive supply house that carries painting supplies. They make an eraser that you can put in your drill, or they fit in a special slow speed die grinder. It will erase the decal and leave NO damage to the panel. Wipe down with some lacquer thinner and it will be like brand new. If you cant find them locally I have them.
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5169 |
Wipe down with some 'lacquer thinners' ?? Doesn't lacquer thinners eat into / dissolve Paint ? Gary |
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
A gentler solvent would be denatured alcohol or mineral spirits or even goo-off.
1957 WD45 dad's first AC
Kcgrain
It wont eat cured paint, and your not soaking it, it just removes the slight film left by the eraser. Dump some on a rag and wipe it off. I've been using those erasers for 20 years , you can try milder, but it usually doesn't take all the residue off
Dale
Thanks everyone for the advice!
Toscani NE SD
Orange Level Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
use DuPont 3812s to remove the tiny amount of adhesive that may be left, after you use the eraser, never thinner.
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
I used a arisol spray in a can (can't remember the name) when I took decals off cruisers. I jusr sprayed it on and within minutes you are peeling them off. leaves the paint on under it. got it at an auto parts store....called decal remover.
truckerfarmer
Orange Level Access Joined: 26 Jan 2013 Location: Watertown, SD Points: 3178 |
I've used a heat gun and a plastic putty knife to remove lettering off equipment at work. Plastic putty knife helps to keep from scratching the paint.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Final consensus? More than one way to skin a cat. LOL
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
I've seen the results of the eraser on a GMC P/U, and the guy is a real stickler for neat! You could not see any remenent of the decals.
Post Reply | |
