Input needed on 6500/7000 lbs. Special farm class. |
AS185
Silver Level Joined: 23 May 2012 Location: Waupaca Points: 91 |
Posted: 23 Mar 2013 at 12:44pm |
I'm putting together some rules for a class, Input needed. 6500 or 7000lbs. This is what i came up with so far. 310c.i. max, stock block and head. 2.3" charger max. No P-pumps. Diesel only, no alcohol or gas tractors. Water inj. Ok. Intercooler ok. No component tractor. Air shut off. Deadmans throttle. Wheelie bars. This will be for a class in wisconsin. An affordable 301 Allis class. This would seem to be a class for Allis 301, Fords 7600, there are alot of good running fords around here. I don't know the cubes on a JD 3020 diesel. or the IH 460/560. What do you guys think?
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2534 |
RPM limit, roll cage or not, blankets/side shields, tire size. Just a few I can think of. Sounds like a nice starter class.
AaronSEIA |
AS185
Thanks Aaron. The few classes we have around here you would need a blanket, side shields, and cage if it's open r.p.m. I was thinking of 4500rpmgood limit?
AaronSEIA
The "off the farm" type classes around here tend to be 3,000 rpm limit, 18.4 rubber, no cage. East Central Iowa has a nice set of rules. http://www.ecitpa.net/pages/2012-Rules.html The hot farm class rules are the ones I'm thinking of. Twin States is another one that has a nice set of rules. http://www.tspapulling.com/uploads/Rules_12_draft.pdf
AaronSEIA |
cwhit
Orange Level Joined: 12 Sep 2009 Location: Sigel IL Points: 963 |
RPMs up to 3000. I would not let then go over that.
Fields
Orange Level Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Thats good. There is a local class like that. Only two 190 allis tractors in it. Post some dates I'll let them know about it.
MACK
Why no gas tractors? Better have a steel flywheel. If a plunger sticks the govenor is out of the picture. No limet on the RPMs it will turn. MACK
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7952 |
After that accident that happened last week, every tractor should have flywheel protection, 1/4 steel over the top and the sides is all it takes
AS185
Doug, what happened a flywheel came apart?
AaronSEIA
A young puller from Ohio (I think) was working on a tractor when the rack stuck and off she went. Flywheel exploded from what I understand.
AaronSEIA |
DougG
Adam Buehl, i believe, details are on Pulloff
O.P.S. Heads
Orange Level Access Joined: 02 Jan 2013 Location: Iowa Points: 574 |
My two cents are that if you are going to have a 310 C.I. maximum
and diesel only, you have limited your possibilities of how many tractors could
be in the class. You may want to consider a larger C.I. limit on the diesels,
or add in gas tractors somehow, or do both to have a class with a larger amount
of entries. As far as pump limits, it seems to me you have three choices: 1 – Stock pumps. a disadvantage to the AC’s and some of the others who are stuck with a Roosa Master while red and green tractors get something better. 2 - No P pumps: To say everything is OK but P series pumps just leads to some very expensive A series pumps that will produce almost as much as a P pump. If you try to limit the size of an A series pump you have just made a nightmare for the tech officials as far as policing the rule goes. I think the 2.3 inlet turbo rule is a good one. There are many different brands of reliable, affordable turbo’s in that size range. !8.4 X 38 tire is a good one also. Yes steel flywheels and clutch components are a must. 3000 RPM would probably draw more entries as well. All in all I think you are on to something. Do your research and ask other organizations how there rules are working before you set your rules in stone. Better to get it right the first time, then to have to adjust them every year.
Good luck. Edited by O.P.S. Heads - 24 Mar 2013 at 10:38pm |
MACK
Steel flywheels don't cost that much today. In some cases a automotive steel flywheel can be adapted at a low cost. Also a steel pressure plate is inexpensive.
People spend more on a good pump than a steel flywheel would cost. MACK
