Multi purpose bucket |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29795 |
Posted: 17 Jul 2012 at 2:57pm |
I have been having the big issues on mine, finally got the strainers(both) out of the trans and cleared them, the bottom one was a hairball, the main feed supply strainer was absolutely a chia pet with so much crap attached to it, you may want to open them up while you work on it. I had to make my own gaskets but they are not that hard to do, NAPA sheet stock paper gasket. The main feeder was slowing my steering way down, to the point it would just quit, today I ran it for an hour and a half before the two steering filters finally loaded up, should be close to the bottom on bottoms rubbish. Had a problem getting the steering pump to prime itself yesterday, figured the pump was shot but pulled the inlet hose today, a little ATF down the throat and it pulled suction and started working again.
My Hydraulics also bleed down, just par for the course on a old machine I think.
doctorcorey
Orange Level Joined: 17 Jul 2011 Location: S. KC Missouri Points: 570 |
No new control valve yet. I'm going to pull down the lift rams and repack them. I'm waiting for my new tranny pump to arrive so I can straighten out my pressures first. Then I'll finish my restoration. The machine works just fine, but I like everything to be in the "green".
Still pretty cute, you get your control valve from the old boy in Illinois to stop the bucket creep Corey?
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22816 |
Hope the bucket cylinders don't leak down
doctorcorey
There were armadillos in the area.......
