What's your favorite engine heater |
Osage_Orange
Orange Level Joined: 11 Sep 2009 Location: SW MO Points: 1593 |
Posted: 02 Feb 2011 at 10:45pm |
for a WD45? Temp in single digits today, went out to start the 45, and it just groaned. Going to have some type of heater for next round of cold/snow. I'm thinking of a frost plug heater, but maybe there is something that works better. (tractor sits in a shed with one side open, so it's like being outside, but protected from rain, etc.)
Why is there never time to do it right the first time, but always time to go back and fix it?
AC WD45
Orange Level Joined: 28 Sep 2009 Location: Mid Michigan Points: 1993 |
The old fashioned way:
German Shepherd dad
1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193 |
AC WD45
Note the card board LOL
German Shepherd dad
Claus
Orange Level Joined: 09 Dec 2009 Location: Hebron In Points: 1150 |
I don't think that is going to help get it started in cold weather, might help keep you going in cold weather.
AC WD45
For getting it started? Ether, hand crank, foot clutch lock. make friends with it.
Edited by AC WD45 - 03 Feb 2011 at 12:55am |
German Shepherd dad
SHAMELESS
Orange Level Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
block heater works the best i think!
Gary in Texas
Orange Level Joined: 11 Sep 2009 Location: Burkburnett, TX Points: 630 |
How do you install a block heater, or frost plug on a WD?
I would think a tank or hose heater (CATS)? use heater hose or lower radiator hose?
Steve M C/IL
Orange Level Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
No freeze plugs in WC-D17.Takes a tank heater and some engineereing.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21484 |
How about using an infrared light bulb as a heater? Like the ones for keeping chickens or french fries hot ?
Placed under the tractor, it should heat up the engine not the air ?
No risk of 'frost plug' problems.....especially in this weather !
Lonn
My favorite is a nice warm spring breeze maybe in May.
Wink I am a Russian Bot |
R.W
Orange Level Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
Salmander heater and tarp!
wf32
Silver Level Joined: 13 Sep 2009 Location: Brownsville MN Points: 455 |
cheap and easy heater is a magnetic heater and can move to different tractors as needed
Phil
john(MI)
I have always trusted the steel trouble light with a 100 watt bulb. I also have a dipstick heater that worked great in a pickup I had once.
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Get a battery maintainer. If the battery has a full charge it will crank. I have them on everything that's not used on a regular basis. The batteries will also last longer if kept charged.
1957 WD45 dad's first AC
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3894 |
Hook A tank heater into the block drain donw by the carb. run the return hose up to the plug in the left side of the water pump. only takes a few minutes to install. put a street L in the block and the barbed fitting into it. This way you won't have a kinked hose. I installed mine last winter when it was -20 F. I also have a tarp wrapped all the way around the engine. It started without it but you couldn't use it for 30 minutes. With the block heater plugged it about 30 minutes earler I can start and use it by the time I get the extension cord out of the way.
Chris/CT
Orange Level Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Magnetic heater stuck on pan, tractor out of cold wind, warm oil, engine will crank better, and if all is tuned fire in 2-3 seconds, ready to work.
MNfarmerAC
Silver Level Joined: 28 Jan 2011 Location: Palisade MN Points: 98 |
I started my 170 at -15 one morning and that was after being town to -30 the night before with no heater. It has a new battery in it and I rebuilt the carb. Had to crank it a few times on full choke but she eventually took off. I would check the battery and make sure everything else is up to par... it should start. Mine sits under a roof but is open on two sides too.
Brandon
1974 185 1977 185 |
Brian Jasper co. Ia
0W-20 Mobil 1 oil in it and no heaters are needed. The CA starts easily and oil pressure builds quickly with Mobil 1.
Chris/CT
Hear here on the Mobil 1, using 10/30 here in winter,20/50 racing formula hot months
j.w.freck
Orange Level Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
on all of our 45,s on the farm in indiana,we had heaters installed in the drain ports of the block.it had an electric motor type pump that kept the water at about 70-80 degrees when plugged in on shut down.definitly need on on the 45 diesel
