CA rear axle question. |
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4435 |
Posted: 09 May 2024 at 11:55am |
Why would you want to remove the axle clutch on a CA, unless you are making a dedicated puller? That is what makes the CA such a great little tractor. If the axle clutch is in proper working order, it will transmit more power that the engine clutch will. There is no locking set screw on the right brake drum that is part of the axle clutch, however there is a set screw in the Left brake drum. The left brake drum is the same part that is used in B & C Tractors.
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2156 |
I had a CA opened up recently for hand clutch repair and don't recall a set screw for the brake hub.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78084 |
Below is a picture of the B-C final drive and set screw on the brake hub... I ASSUMED the CA was the same, but the book does not mention a set screw and has no photo.. The removal is basically the same as the LARGER tractors... just "use a puller" according to the book.... press fit.
Edited by steve(ill) - 09 May 2024 at 7:57am |
UPBUSHMIKE
Bronze Level Joined: 26 Jul 2023 Location: Yooper Points: 40 |
Does anyone have a pic of the RH drum showing the location of the locking setscrew? I cant find it with a flashlight. To the best of my ability, there is NO setscrew visible and accessible thru the bottom casting hole. Thank you!
YES... the brake drum presses onto the shaft and has a key way .. setscrew on the brake hub access thru the round hole on bottom of case.. Edited by steve(ill) - 06 May 2024 at 8:17am |
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8035 |
I doubt it. Wd's -D17's were press fit. I don't know much about a CA
UPBUSHMIKE
looking back at several old threads, I have still not found definitive answer…..is there a locknut on the RH brake drum? If so. i can not see it turning the pinion shaft and looking with a flashlight. Where is it? The service manual is next to useless in my opinion.
im4racin
Orange Level Joined: 12 Jun 2017 Location: Garrison ND Points: 844 |
The axle shaft is the same. It's the pinion shaft in the final drive you want to change.
UPBUSHMIKE
looking back, I see you basically said the same thing im4racin. Thank you.
UPBUSHMIKE
thank you Steve! That is GREAT news. I just want the tractor useable for now. I realize the axle housing is asymmetric, but thought maybe the longer straight axle would work.
yes.. the AXLE will work.. you cant use the HOUSING.
im4racin
You can't just move the housing. the final drive is tilted to the rear. If you put a left on the right it will have 2 different wheelbase depending on the side of the tractor you are looking at. Go look at yours and it gets pretty obvious
UPBUSHMIKE
you say no, then say yes? Which is it?
im4racin
Short answer is no. You can take the shaft out of a LH axle and put in the RH side.
UPBUSHMIKE
Will the LH final drive axle work on the RH side to remove and bypss the hand clutch?
