Looking for Bearing Numbers |
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 1804 |
Posted: 26 Apr 2024 at 8:05pm |
Does anyone have a listing for aftermarket engine bearing numbers for an 11000, or 685T series engine? I have OEM Allis Chalmers numbers but damned hard to cross via internet, or auto parts stores. Got one old Napa store to visit but haven't had time during normal business hours yet. They still have their old books. Doesn't matter if Federal-Mogul, Sealed Power, Clevite, Michigan, TRW, Mahle, etc. Got an R-72 combine coming in on trade that is worn in and out, but still runs well. It could use an engine freshening but rods and mains are elusive to find. I'm wanting to retain the engine and part the rest reasonable in pricing. Thanks, |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41214 |
Allis Chalmers 685T, 10000, 11000 Diesel Rear Crankshaft Wear Sleeve, 74029556 ; Availability: ; Part Number: 474029556 ; OEM Number: 74029556 ... |
Codger
Thanks Coke. Gaskets and seals are relatively easily sourced for this engine, (albeit expensive) with a couple week turnaround. It is the fluid film journal bearings I cannot cross into the aftermarket and being pursued in this quest. I have a used set from an engine rebuilt years ago I can reline if need be ultimately; however, installing new would be a lot easier overall.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4427 |
I have an old Clevite book that lists the following part numbers:
Rod bearings; CB-700P round oil hole CB-1369 offset oil slot With flanged #4 main on #4 main #4 flanged main bearing; MS-769P With trust washers on #4 main bearing #4 with thrust washers; MS-770P T.W.4 MB-2096WU 2 pcs req'd included in main set T.W.4 MB-2096WL includes dowel pins 2 pcs req'd included in main set T.W.4 TW-441S Components included in main set, or may be ordered separately Late style with oil slot M.S. MS-161P T.W.4 MB-2096WU 2 pcs req'd included in main set T.W.4 MB-2069WL 2 pcs req'd included in main set T.W.4 MB-441S Components included in main set, or may be ordered separately I definitely doesn't look as just 1 part listing will fit every engine. If you have a NAPA store in you area that has competent counter help, consider yourself lucky. Around here a NAPA store is just about as much of a time waster as going to a TSC. |
Codger
Thanks Paul; The mains it seems are to remain elusive. Poking around on the internet early this morning I found a "Mahle Aftermarket" catalog showing the same numbers you have researched and the rod bearings are seemingly still available, or a current offering. The mains are not listed as current and a quick search provided nothing tangible in result. You're right about the Napa stores any longer. Such a shame too as always used them in the past but no better than anyone else nowadays. They, (local store) still have all their old literature to go through and that has helped a lot.
im4racin
Orange Level Joined: 12 Jun 2017 Location: Garrison ND Points: 842 |
I think the bigger question is when did the R72 come with an ac produced engine?
Codger
I was told it was original to the machine? Never been around any of them myself so no idea.
Codger
I mixed that up. It is an N7 combine being traded for an R72. The N7 has the Allis engine and I don't know what is in the later unit.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77894 |
You might ask these guys some questions//
Codger
Thanks. I did not realize they were into anything but reproduction manuals. Talked to several that vendor the Reliance brand of parts and nobody has mentioned these shown here? I'll get a number and call them. Thanks again,
Coke-in-MN
figured that site might have had lead on other parts also - not just gaskets .
Codger
[QUOTE=Coke-in-MN]figured that site might have had lead on other parts also - not just gaskets .[/QUOTE I've used them several times in the past for both gaskets, and hard parts/items and was told in gaskets they only offered what Victor/Reinz offered at the time under private label. Until recently, had never heard of the "Reliant" brand. However, searching Reliant's website directly, there was no listing pertaining to the engine I'm working with for main bearings found and the reference posted by Steve is quite a surprise to see them exactly from that brand. Several sources list the rod bearings as the number is relatively commonplace in many older engines. This needs further investigation as I have several old engines that are long extinct for many parts and bearings. Thanks again,
