Hard pulling main clutch |
RSWarden
Bronze Level Joined: 21 Apr 2024 Location: Oregon Points: 4 |
Posted: 21 Apr 2024 at 12:40pm |
I've an HD6 with a very hard to pull main clutch. It functions once pulled but to engage and disengage it takes much more than the 25-30 lbs the manual says. In reading the manual I see nothing dealing with this. It only deals with a loose clutch engagement. Any one able to point me in the right direction?
Thanks, RW |
gemdozer
The cluch shaft sleeve need lubrification and the greace fitting is on belhousing plate inspection
RSWarden
Thank you! I'll try that and see if that cures it.
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 643 |
There is also a possibility that the line/tubing/whatever connecting the grease fitting to the clutch shaft sleeve inside is damaged or broken and the grease hasn't been getting to the sleeve. It may be worth a look inside the inspection plate.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4370 |
Also hard to engage if it is adjusted to tight. But lubricate the linkage and sleeves as the others advised first.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41229 |
Lube the sleeve and also you might have to back the cultch off a notch or so , lube the ever pivot also . I had to rebuild mine and made a new brass sleeve for throw out bearing .
One thing is do not idle machine while in gear , only in neutral and clutch engaged as it will wear the sleeve . |
RSWarden
Thank you.
I don't idle it in gear or with the clutch engaged. I'll start leaving the clutch engaged if that's better on things. |
Coke-in-MN
Idle in neutral , clutch engaged for longer life .
I put a ceramic clutch disc in my HD5 so little or no slip now on clutch |
