Allis Chalmers C Tractor stopped moving when mowin
Johnniewb1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers C Tractor stopped moving when mowin
    Posted: 14 Apr 2024 at 7:07am
Hello.
I have a 1948 C that I use an underbelly mower with. Last summer when mowing it stopped moving and the pto stopped while remaining running. Starts right up but does not move and pto does not engage, only tried 1x as I do not want to break anything other than what is possibly already broken. Have not split tractor yet, been putting off.
Looking through clutch view hole clutch engages and disengaged as best one can see.
IF I put in gear when not running gear engages and cannot push tractor by hand. Moves in neutral. Trying to give as much information as possible...
Any thoughts what caused this and what I should be looking for?
I have seen a post about a cotter pin in the clutch shaft that breaks, but that post indicated would not cause tractor issues when together.
Any help is greatly appreciated.
Edited by Johnniewb1 - 14 Apr 2024 at 12:49pm
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 8:05am
Total stab in the dark but it sure sounds like you have something jammed in the gear box/ pto.  If clutch works but tractor won't move at all in gear I don't know how it could be anything else. Rear end issue wouldn't let it roll at all, so maybe start with pto as it may be easiest and least intrusive to remove and check for obstructions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 8:18am
If the tractor will not move... AND you have no PTO drive... then you have a problem with the drive shaft out of the main clutch to the transmission. That is the only thing that effects BOTH...When the shaft gets to the transmission, it GEAR DRIVES two different shafts for the trans and pto..
could be the splines in the clutch, could be the splines on the shaft, could be the coupling to the trans shaft..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 8:21am
you might be able to put the trans in neutral, engage the PTO shaft ( not running engine).. have someone turn the PTO shaft by hand ( or small pipe wrench)... while you look up at the clutch from the bottom.. dont know if you can see much of the shaft BEHIND the clutch.. see if the shaft moves and clutch is slipping or if shaft does not move ( rear coupling problem).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 12:48pm
Thank you. Did these steps without tractor running.
I engaged the pto, was able to turn using pto side pulley that runs mower deck. Mower deck blades moved as they should and rear pto also spun. Through smaller port window above nut that holds wishbone on I could also see the flywheel unit spin as well.
Engaged tractor into 3rd gear and was able to move tractor forward using pto. Does this provide any additional help in helping me to figure this out? I appreciate the help thus far.
Edited by Johnniewb1 - 14 Apr 2024 at 12:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 1:16pm
The PTO and transmission are geared together inside the transmission.. IF you engage the PTO and put trans in gear, YES, you can drive the wheels with the PTO shaft..
You should also be driving the driveshaft up to the clutch.. You said you could see the flywheel ( or clutch case) turning, as it should.... if the FLYWHEEL is actually turing, then the engine will be rotating.. Can you see the fan blade moving when you turn the PTO shaft and tractor is moving ?
I guess if the flywheel is actually turning with the rear end, then it is POSSILBE that the flywheel is no longer connected to the crankshaft, or the crank is broken by the rear main ?? But i would not expect that..
You could pull the starter and BAR the flywheel over with a prybar and see if the engine turns over... also tractor should move if trans is in gear..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 1:25pm
With pto engaged fan blade spins. So thinking I am thankful for that!
Have not restarted tractor since this happened last year.
But tractor did immediately fire back up from starter last year when I was questioning what had just happened after I turned it off when it stopped moving and mowing.
So is this pointing towards a clutch issue? Clutch had been replaced about 5 years ago at this point I am guessing.
Again I am very appreciative of the help as I would like to get this tractor back up and running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 1:33pm
Sounds like everything is in place and not "BROKE".... Seems like the clutch is worn out, NOT ADJUSTED right , slipping, or the coupling is sheared and not transmitting full power.
You might look at the clutch SPRINGS and FINGERS from the bottom and see that not broke, stuck, and all adjusted the same....I would be temped to start it back up and try again after that ...
make sure the clutch throw out bearing is OK and the slide is not STUCK.. play with the foot pedal and see that there is FREE PLAY in the pedal / rod, when clutch is engaged.
Edited by steve(ill) - 14 Apr 2024 at 1:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 1:38pm
I did check clutch fingers last year when I gave up, all springs in place and it looks good.....
Where is the coupling your are referring to? In front if the gear box or ? I do have 3 different manuals that are helpful, but....
I also have thought about restarting and seeing what happens, but didn't want to create any additional issues
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 1:39pm
Fingers are in spec I should have said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 1:52pm
By coupler are you referring to the end of the drive/clutch shaft at the rear connecting to the 'gear' box area? Sorry for poor terminology.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 3:50pm
Yes... the transmission shaft sticks out 2-3 inches infront of the case.... the "DRIVE SHAFT" sticks into the clutch and extends back ( about 3 ft ?) and then connects to the transmission shaft... Couple different designs over the years.. Some had a retaining cotter pin as you said, so when you pull the motor out the shaft pulls out of the clutch and stays inside the torque tube attached to the transmission.. some dont have the cotter pin.
To attache the drive shaft to the transmission shaft, i have seen splined sleeve retained by a cotter... have also seen a cheap typ u-joint used....
Seems like there is "MORE STUFF" at the clutch end to go wrong than at the rear of the drive shaft ??
Edited by steve(ill) - 14 Apr 2024 at 4:03pm
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 4:15pm
You can see the cotter pin by removing the steering wheel brace/ pipe. The b we had at work was just the smooth drive shaft, no spline. The one guy would always pop the clutch and shear the pin. I’ve tried cotter pins, split roll pins the finally used a grade 8 bolt and nut. You can change them from that hole if you’re patient. Lining the holes is the worst part.
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 4:38pm
Thank you all, so if the cotter pin is missing could that create this issue of loss of mobility?
I think I will start there z easier than splitting to start at least! Understood on grade 8 bolt! Length and size known?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 5:58pm
I have never seen a setup where the cotter pin was taking the load.. All i have seen the cotter doing is keeping the shaft connected to the trans, when you pull the engine out the front... I dont see how a smooth shaft with a cotter pin would drive.. You would be relying on the pin to take 20 HP.. that wont work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 5:59pm
Took apart steering column post, pin is sheered. Bigger issue is that when clutch was replaced few years back or maybe even before then the holes are no longer aligned. So if this is believed to be contributing to my primary issue I am left with no choice but to split.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 6:00pm
Steve, you think clutch then or ...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 6:09pm
The "coupling" or "u-joint slides onto the splined shaft of the transmission and the cotter pin retains it so it will not fall off... The OTHER side is attached to the drive shaft.. Is the broken PIN on the drive shaft, or the retainer for the trans end ?
I dont really remember how the coupling is attached to the drive shaft.. I would not think a small pin would be enough to handle the HP.
Edited by steve(ill) - 14 Apr 2024 at 6:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 6:12pm
Steve. The trans shaft is splined but the drive shaft looked to be homemade repair. It had a universal but a pipe was welded to it then pinned to the trans shaft
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 6:13pm
The sleeve that goes onto the shaft going into transmission/gear housing under the steering column is the pin that broke. The pin to hold in place when separating I imagine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 6:14pm
Mine is original, no repairs as far as I know!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 6:20pm
If the u-joint or original coupling failed and they just welded a piece of pipe to the drive shaft, slid over the trans splines and put a pin thru the retainer hole.... YES, that could be a problem.. I dont thin a 1/4 inch bolt is made to take 20 HP... that is what the splines on the trans shaft and the splines on the clutch hub are for..
i think i am getting john and johnnie mixed up.... johnnie, your "PIN" you said is broke or missing... but you should have SPLINES on the coupling or u-joint to drive the shaft... all the PIN does is retain it.....  John was speaking of a MODIFIED drive shaft without the factory splines..
Edited by steve(ill) - 14 Apr 2024 at 6:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 6:25pm
(I guess if you can align the holes and pin  thru the pipe tower hole, that would be a quick fix.)-----jphnnie.. i dont think this is your problem... it ws JOHNS probelm.... but i dont think a smooth sleeve over the spline shaft is a good design.. And you will not be able to split between the trans and torque tube... if you do, the shaft will pull out with the clutch and torque tube... then you will need to pull the engine to get the shaft back into the clutch after installing the shaft onto the trans... ??????
Edited by steve(ill) - 14 Apr 2024 at 6:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 6:28pm
Steve, mine is original as far as I know. The other John was indicating that with his B. If I split I will do so at the clutch end of torque tube not gear end.
I am going to put steering column back together later this week and fire it up, see what happens......
Edited by Johnniewb1 - 14 Apr 2024 at 6:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 6:32pm
YEP... i just figured out that john and johnnie are two different tractors... I think your on the right track now... I just updated my OLD POSTS..
One thing you MIGHT want to do is start the engine NOW and look down the steering column hole and see if the drive shaft is TURNING.. Probably NOT... so you have a CLUTCH END PROBLEM.
Edited by steve(ill) - 14 Apr 2024 at 6:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 8:35pm
Sorry for the confusion, I was just saying what the tractor at work was. I did the bolt over 15 years ago and it is still working. All it does is mow grass with a woods l59
Edited by john2189 - 14 Apr 2024 at 8:40pm
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnniewb1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2024 at 6:43pm
Had to buy new battery, pushed outside as is stored in my basement. Fired up first try, engine is great!
Pushed in clutch put in reverse and backed up about 30 feet. Pushed in clutch, put in 1st moved about 5 feet and then it stopped. Initial slight noise from under steering column and through bell housing of clutch. Noise is like a vibration, hard to describe. Would not re-engage to move. Pto would engage at low rpm. Noise does not appear present in neutral. Pushed back inside
will be splitting or probably into 3 pieces in the next few weeks. Any additional thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2024 at 7:18pm
I think your on the right track... Im betting on the clutch plate splines / broken plate ... or in that area.
Edited by steve(ill) - 16 Apr 2024 at 7:19pm
