Need a way.... 220 AC
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: Need a way.... 220 AC
    Posted: 26 Mar 2024 at 2:47pm
...to put 10 bolt pressed steel wheels (off an L3) on a 220 - AC 3 5/8" axles.
Have 3 3/4"  hubs and many OEM wedges / wheels.  Need a way to install 30.5 x 32's on the 220.  Have one MexHat center as well if anyone interested or has an extra.  Was able to put 24.5-32 on our  D21 by using 3.25" MF (ok, best I could do) swedge hubs.
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 5:58pm
I have a single mex hat cast center, the large one that mounts to the 38" rim
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 9:30pm
I sent a private message to each of you. Mexican hats are no good as a singles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 6:38am
I think there is a Deere tractor axle that they call 92 MM that is very close to 3 5/8".
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 11:00am
Yup, Doc, just found a set - 92MM- 3 5/8  the guy won't sell..grrr - will keep looking..
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 1:32pm
CAP Bros hubs, he has 9/10 bolt hubs, but they are more expensive than plain old dual hubs. I'm running a set on my 210 TooHotToFarm. The nice thing is they are narrow, so it lets you have more freedom of placement on the axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 11:44pm
Are you trying to stay away from cast centers? I've got 30.5's on my 220 but that's with 32in centers. Was original with 24.5's and I came close to putting those 92mm Deere  centers on and going to 38in rubber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 11:38am
You seen the prices on OEM 32" centers / rims   :-)   I have one 210 with 24.5/32 's
