Allis 416
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: Allis 416
    Posted: 19 Feb 2024 at 11:35pm
Good evening!!
So I’m wondering if John Deere low velocity hydraulic oil would work in the hydro?
I just got it running for the first time in who knows (the battery was dated 2000) and it had a hole in the block from the balancer gear breaking.
I took the block into my local blacksmith and he patched the hole and I put a new piston and rings and now it runs great!!!
I have a tiller, mower deck, front blade, snowblower, and a little Allis cart for it so it’s going to be worked pretty good….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2024 at 12:32am
Nice resurrection.
What did they do to fix the block.
We have some nos parts for that mower deck and tractor if you need anything
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2024 at 9:41am
Can you look up Allis part numbers?
I have a original parts catalog for them but the nearest agco dealer can’t look any numbers up…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2024 at 12:36pm
Yes my grandfather was a dealer then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2024 at 10:47pm
So as I’m using the tractor it seems to be a weak hydro going backwards, forward is fine but if I back up over a bump it will stop…
I’ve adjusted the turnbuckle so neutral is correct (I think) so I’m wondering if anyone else has had that problem?
Mikez, I’m working on a list of things to price and I will private message you when I complete it…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2024 at 10:24pm
Well I may have fixed the reverse problem…
I extended the arm on the hydro lever so it will have more movement…
Pictures aren’t very good but you can kinda see what I did..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 9:47am
Well it’s about to become a 416h3…
Yes I’m adding hydraulics to it with 3 ports…
So far I have a 5.9 gpm pump ,part of a tank (somewhere around (2-2.5gall) still needs hose ports.
Will get pictures soon but I have the hydro pump apart to put new O-rings in the control lever shaft.
