allis chalmers hd 16 dp buda 844 engine
Message Reverse Sort Order
russell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers hd 16 dp buda 844 engine
    Posted: 30 Apr 2024 at 6:19am
Hello
I have not been on here for awhile busy on farm
Thats some interesting reading on the crank shafts
I still have not had the time to do any more on my crank shaft
work in progress
cheers
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 3:59am
Just remember that Allis also had a plant here in Oz.  And the serial number of the Oz assembled AC Forty Five grader we have  looks like nothing in the official parts book.  I have it "sort of almost" translated by "does it have  or not have" various upgrades in the parts book.   IIRC the model was "124".
Locally constructed comopnents meant lower import duty.  Example was that the Bucyrus equipnent for IH was done by Armstrong Holland under license.
I have no idea what level of assembly the pieces they got were.  But businesses weren't above shoving obselete components off to places like Oz.  You may think that the last Ford flathead trucks were 1953 - we have one bought new in 1954 - with Lucas electricals. The "Y blocks" arrived about 1955.
The neighbour I mentioned has had a lot of Allis experience.  To the level of when his 16 DP got sick he took it to a major in the game.  And came home with it overhauled and about 40 tons of Allis dozer parts as that major was concentrating on "Komatterpiller".
He was very helpful with our grader resurection.  And his work is first rate.
His (non-Japanese) crankshaft experience was (IIRC) - his was cracked, 2 tagged good were cracked and finally he got a good one.  There was a nest of HD 16 and  21 owners in the area and cranks were a barbeque topic.
His mention of "one source" for things 17,000 was components being brought in by an importer with South Korean connections.  I guess he didn't see many official ones.
Edited by Ian Beale - 29 Apr 2024 at 4:00am
ACjack View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2024 at 8:30pm
During the time I worked ( late 1969-1973) in department 75 (engine assembly/ repair) all 16000 & 17000 series engines had the 6 count counter weight crankshafts. There was no difference in the crankshafts as-to what engine they were used in. ALL 6 count weight crankshafts were forged in Japan and shipped to the Harvey Engine plant where they were machined. There was no different importers used as to 16000 series vs 17000 series.
  After I got into inspection and later became the Customer Product Auditor I had the opportunity to have a conversation with one of the metallurgist concerning the quality of the 6 counter weight crankshafts. He told me that crankshaft had elevated levels of impurities and poor grain structure.
 Long story short it wasn’t all that great and nowhere near the quality of the U S made 12 counter crankshafts.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 9:47am
16000 series is the 3 valve head and would have been out of production several years before the DP tractors were released
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 4:13am
I have a neighbour with vast experience of Allis dozers.  He owned what would be a candidate for the best working HD 16 DP in Oz - machinery wise, not so much paint and decals.
I talked to him at the ANZAC service today and mentioned your Japanese crank.  His comment was that there were 16000 series and 17000 series engines we got here.
Seems the 17000 ones came via a particular importer.  He described them as "looking like a 16000 but weren't quite" and that he had never followed up in detail.
FWIW
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 6:00pm
Thanks Eric
I have not had the chance to get back to the crank i have a lot of cleaning up to do there hope i get the metal of and its ok underneath
cheers
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 1:35pm
I know Codger has you well covered, I'm encouraged by the one picture of the journal. Measuring the journal with a calliper will be important. What I would add is using plastigauge if you manage to get a hold of a new set of bearing shells. Even if the clearances are critical it may do for an OK bandaid for your dozer. You would need to determine that your rod is acceptable without resizing and yet if that would be a game changer it's worth pulling the head and that one piston. This may be somewhat of a gamble but it wouldn't have to cost you much money...
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2024 at 9:02pm
It can take some time and elbow grease when attempting to not do further damage. I've seen many engines over the years carry great oil pressure hot and cold but still starve the rod bearings out on supply as they gain clearance over time and usage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2024 at 7:42pm
Thanks codger
I will do a bit more and see how i go with the 320 probably just one of those jobs that take time
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2024 at 7:38pm
Hi Russell;
You could start with 240grit but it will scratch deep if aggressive. That bearing has been very hot to be adhered so tightly. Not what I consider abnormal as the appearance from your other bearing shells reveals oil starvation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2024 at 7:18pm
Hi Codger
Had a couple hours spare yesterday started to emery crank shaft i spent probably a hour or so but did not make a lot of progress still plenty of white metal on the crank shaft is this normal? using 320 grit paper wondering if i am doing somthing wrong or its just one of those jobs that will take lots of time
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 9:15pm
Hi Russell;
Don't know if I've ever seen an engine where you could remove the wrist pin from the piston with the crank still in place. I really cannot say for certain but probably not. Many times those pins will push free with a little force after the circlips are removed from their ends. Sometimes a little more force than fingers is needed and I've used a large "C" clamp and spacer a lot of times but usually a hydraulic shop press is the tool to use.
I would get those exhaust studs and/or nuts soaking in 50/50 ATF Acetone mix a couple of times per day. Then a torch to warm the fasteners red, allow to cool, then red again and after a cooling period attempt to gingerly break them free. It would be helpful if a helper were to warm the area around the fastener just before you apply torque to the frozen fastener to expand the direct area. The penetrant works, but takes a while when things are really bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 8:42pm
Hi Codger
Thanks again i will have to get some 320 grit emery this is a different question if the crank is ok would it be possible to pull the piston downwards enough to get conrod off ? Im not sure if gudgeons pins are press in or just slide in just a thought . I guess the crank journal is the first thing and go from there. Looking at the exhaust manifold bolts they are going to be a big problem nuts are rusted pretty badly i guess i could just cut them  of and try remove studs latter.  Did ails ever make a tool to hand wind the motor over i have been baring through the timing mark plate its ever so slow any way first job crank shaft go from there thank you for your help
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 7:42pm
Hi Russell;
I typically use 320 Emery cloth when polishing journals. Also use a light machine oil and polish just till a clean surface. I expect you will need another connecting rod but am always conservative on the internet with suggestions as to not paint "doom and gloom" which is so prevalent. I think if the crank journal is found to be good, you can pull cylinder head #1, install a bolt and clipped washer into the block deck to ensure the liner doesn't push out of the block while you push the piston and rod out from the bottom to renew the connecting rod. Hopefully the prognosis is good once the crankshaft is measured up. Many times a rod can be resized, but many times not.
I wouldn't attempt to pull the engine with the hard nose and radiator in place myself as it needs to move forward to clear encumbrances to remove. Usually best to lift a little and pull more from the front than straight up. A wheel loader, or crawler loader is a good tool to use for the lifting as everything is heavy. Hopefully you can do an inframe rebuild and all be good. Regardless it will be much easier to work with if the blade and push beams are removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 6:36pm
Hi Codger
Thanks for the reply Do you have a suggestion for the grade of emery paper to use i have plenty here but its pretty course i think its about 120 grit . I will have a look at my micrometres i have here im not sure i have one the right size you would kind of think with the bearing halves stuck together that the conrod would have to be out of round but like you said start with the crank. Do  you know  or would some one else know if its a big job to get engine out of the dozer ? can you remove engine with out removing radiator
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 6:13am
Ok Russell; The engine may need to be removed for repairs. However to ensure the crankshaft will require regrinding it needs measured up before going much further. I would take an inch wide and 18' length piece of emery cloth strip and after rotating the crankpin, (journal) to the bottom of it's stroke and pushing the rod away for clearance, polish that journal with the abrasive pulling the emery cloth fully around the journal each way using your hands. Usually the soft babbit, antimony, and copper based materials will easily remove with the cloth. You will than need to clean that journal using a clean, lint free cloth. Using an outside micrometer measure the journal top and bottom, and side to side at perpendicular axis to one another. This will tell you if the journal is out of round. Any more than about a .001" - .0015 out of round and the engine probably won't hold a bearing very long. If the journal is out of round, you can wager the rod is also and probably worse. These most times can be repaired also, but it requires cutting the cap and resizing the rod journal end to correct dimensions.
If it were me, I'd clean that journal up best possible with engine in the tractor, get a good measurement and ascertain this part before going further. If proven satisfactory for both dimension, and out of round, then rotate the crankshaft 90 degrees, and pull the rod and piston down with a wire around it's base, install the rod cap, and measure the interior at 90 degree spacing basically the same as you did the crankshaft journal. If anything is found out of tolerance, the engine will need further repair.
Given the scuffing I see on the other bearing shell you posted, the engine could use a "freshening" which is easy in the grand scheme of things. Citing the engine still has standard sized journals is in your favor for economical repairs, (relatively speaking).
I'm interested in what you find out with the measurements. Keep the sump mounted back up onto the engine to preclude any rusting from the humidity in the air too along with catching airborne dirt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 4:28am
Originally posted by russell russell wrote:
Hello
Well had some rain dust settled decided it was time to pull the sump of the engine . Once of all looked pretty good no discoloured caps no metal showing up so i decided to grab hold of rod ends and could move just a little side to side all felt good but no movement in number three so im thinking this is the problem it got dark so left it at that will have a go at pulling rod cap off today and see the result .
cheers
Another way to check this is to take a long tapered punch, hold the punch in your hand and swing against an anvil striking the hammered surface, to the anvil.  remember this sound.  Ping!  now strike against each individual bearing cap(if there's room!)  the bad one(s) will make a Pock sound, instead of the ping sound...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 11:48pm
Has any one got any thoughts looking at the crank shaft you would have to agree its pretty bad funny thing is not a lot of heat on rod ends or backings hmmm has any one been here before ? Is the metal on the crank just soft metal and if polished off crank may be ok? Its the Japan crank which i was surprised with i thought my model still had the usa crank geee i should give up but i keep thinking how good it was when using in the past any thoughts criticism welcome
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 11:37pm
std
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 11:36pm
Std
bearings
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 11:35pm
Codger
next journal as good as gold
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 11:33pm
Codger
a bit different one on top off other
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 11:30pm
Hi Codger
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 10:29pm
Hi Codger
Have apart bearing spun on top of other have photos just not sure on the best way to post on here
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 9:24pm
Anxious to see the bearing shells. Not being loose is positive however you may have turned a rod bearing if it is tight and some times that is not too bad to repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 5:46pm
Hello
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 5:12pm
That's funny right there. Most in reference  to me start the process with the thought "that boy ain't right" so this is a change.
Swear, I must be getting old....
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 2:47pm
Thanks
You are all right dont give up yet i will take the sump off and have a look its very dry here at the moment i will wait until we get some rain as its so dusty and dozer in the paddock
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 9:35am
It appears the std. size rod bearing set in this link are correct for that engine if original to the tractor:
The engine number and the tractor number fit in the search criteria, but without seeing anything it is stated on visual findings only. Until measurements are known, nothing really to be done.
Stephens equipment has some partial items to help build a set, but nothing complete as per their website. I have a couple of other contacts that deal in NOS and good salvage but pricing is reflective of availability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2024 at 8:36pm
Russel
Remember that until you take the sump off and look you don't know that it is the crank area at fault
