Twin charger 301
Message Reverse Sort Order
190xt llss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Topic: Twin charger 301
    Posted: 16 Jan 2019 at 6:40pm
I’ve got 10 over gears and going with 20.8’s
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 6:18pm
A 180 in direct is 22.7 you should be able to get at least that fast 21.6 would be good if your doing it all ? Good luck
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:26am
Best of luck in your build!  I am building a 7000lb Super Light Mod Farm 190XT right now, but my next build will be a twin charger 301.  Cheers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 10:01pm
Power to be had with the newer injectors with 5 hole or even 6 hole !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 4:53pm
Any videos? Sounds like a good one
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 12:31pm
If I can build the power for a faster gear then that’s where I’ll go
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 12:30pm
10% over road gear 6400 lbs
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 12:18pm
So a 190XT with any size twins and 760 cc's of fuel should need a gear waaaay faster than direct drive road gear ?  Yes or No ?? Under 7000 lbs ??
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 10:38am
Doc no intercooler? Over 1000cc on 301inches?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 10:12am
P-3000 capable of 760cc 4x30 injectors yes open rpm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 9:55am
So, how many CC's of fuel and what type of injection pump and injectors do you have? You can run bigger turbo's with 1000 cc's versus 700 cc's of fuel. I assume you are open RPM's ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:14am
I can run any two turbos. No intercooler. Water injection. I might add I’ve already got the head work done and custom exhaust and intake housings to let it breathe better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 7:23am
WHAT ARE YOUR RULES ???? Some organizations only allow a maximum inlet/outlet size !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 7:52pm
Head and flow will be your problem . Can be improved with extreme work !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 7:49pm
Call Dennis at FVP !!!! Smalll s400 and a gt45 on top maybe, just call him .
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 5:31pm
I’m building a llss 190xt with a 301 I’m looking for suggestions on a twin charger setup
