d 17 carb
graveyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Topic: d 17 carb
    Posted: 19 May 2018 at 2:52pm
Looking for a replacement carb on d 17 tsx 561 any good suppliers out there>
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 10:27pm
don't know anything about the seller or the carb, except it does not appear to be a 561
https://www.ebay.com/itm/Allis-Chalmers-D17-D19-Tractor-Carburetor/272828188168?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D50544%26meid%3D4865e0b3feb843bcabfac2e8cdc647c7%26pid%3D100005%26rk%3D4%26rkt%3D9%26sd%3D362190908444%26itm%3D272828188168&_trksid=p2047675.c100005.m1851
However, according to Terry Deans book, the D-17 was produced with 464, 561, 773, or 871 if that helps in your search
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 5:42am
That carb is junk !!! it isn't even all there !! Many pieces missing....... and it is not to any D-17 or D-19, which don't use the same carb between them anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 8:08am
Well, like I said, I knew/know nothing of the carb, or the seller. I guess I'll stay in the politics side, where I'm always right! LOL
Wait for the Lord;
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 8:10am
Wish the seller would tell the truth on that carb... never seen on of them on an allis either... "removed from tractor", what tractor? ... and just some cosmetic wear? No throttle shaft, no throttle plate, and choke rod hole broke out... Should be listed at best as a PARTS CARB...  just another scammin seller. IMHO
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 2:49pm
I have a good 871 that came off a running D 17. Turned out the crank was messed up etc so the carb is available. $150.00 which includes the ride. Den
Own 5 720 garden tractors with associated equipment,1 620 garden tractor, 4 wheel 20
2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 9:57am
This is the reason why I never buy any parts off e-bay!  The only thing I buy from there is operator manuals.
