Shovel Control Valves |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41226 |
Posted: 27 Oct 2017 at 5:39pm |
First off is the drift from valve body or a internally leaking cylinder - drift is generally when pressure is unequal between ends of piston and fluid on back side of movement direction - so a void or open flow no non pressure return side - bypass of packing is another thing
rustydollar
Orange Level Joined: 07 Aug 2017 Location: Manitoba Points: 456 |
Or you could replace the spools with electrically operated then install a joystick for ease of control.
With electric spools your dealing with wires from the joystick, keeps things neat and tidy. http://www.oemoffhighway.com/operator-cab/operator-interface/joysticks/operator-interface/product/10257375/danfoss-danfoss-power-solutions-formerly-sauerdanfoss-js7000-joystick |
rustydollar
6 Bank motor spool valve |
LostDog88
Bronze Level Joined: 14 Sep 2017 Location: Puyallup, WA Points: 9 |
I have the Simplicity/Allis 9020/720 and the boom on the backhoe is drifting when I release the stick. It has 6 sticks to control everything.
I want to swap out this old control valve. Anyone know what I should be "googling" to find a replacement? |
