Allis Chalmers HD9B |
Ralph Odegard
Bronze Level Joined: 08 Jun 2017 Location: Happy Valley, O Points: 6 |
Posted: 08 Jun 2017 at 6:09pm |
I am searching for Oil Filter Cartridges for an HD9B. Engine is a 471 Detroit. Machine was built in 1952. Actually I have two HD9B's with the same standard AC oil filter mounted on the left side of the engine with no numbers or info. Having trouble finding the right cartridge to fit. Important: Measuring the Cartridge Container it appears the cartridge would measure approx. 1/2"ID x 3 3/4" OD x 7" long.
gemdozer
Thanks(1)
The 471 DETROIT ELEMENT OIL FILTER(full flow PF-132)
==========================(by-pass P 117)
Ralph Odegard
I will check out brand hopefully and size measurement, thank you.
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33652 |
WEll, make sure you have all the parts inside to hold the filter securely... I ran across a A JD that somebody forgot to put the spring, seal, plate and snap ring into so there was NO real filtering of the oil... and then I found a McDeering 400 diesel that somebodey didn't bother to put the right filter adapter in... well they didn't bother to put it in, was missing on first filter element so the final filter plugged up.
Ralph Odegard
Still looking for correct oil filter for HD9B. I have two numbers from gem dozer but unable to find brand. Correction on my post : found a used oil filter and have the correct measurements which are 1/2" ID x 3 11/16" OD x 61/2" long (please help)
Ian Beale
Orange Level Joined: 03 Oct 2011 Location: New South Wales Points: 934 |
A quick look on the googler suggests the brand might be AC Delco |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29555 |
Try Application Associates under Baldwin Filters. They have application catalogs for most any machine with access to obsoleted filter by other companies that Baldwin still produces. Is where I buy my filters for my 7G.
https://www.baldwinfiltersrus.com/ Edited by DMiller - 11 Jun 2017 at 5:45am |
The correct Baldwin is a cross to AC PF132 is a P20-HD 4 7/16" OD 1 1/2" ID 9 1/16" long.
This has been a standard sized Detroit filter for a long time. Edited by DMiller - 11 Jun 2017 at 5:59am |
Ralph Odegard
Dmiller, The canister for the cartridge filter is 4 inches inside diameter so of course 4 1/2 inches will not go in . The center pin is 1/2 inches for a sealed fit and the length must be 6- 1/2 inches long, The out side diameter of the cartridge is 3 - 11/16 inches. Thankyou !
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3735 |
for some reason we could not get the bypass filter for our 6-71 in the Hd15,so we plumbed in a new bypass filter assembly.
gemdozer
The elementoil filter p-117 DETROIT 5572425
--------------------PF-132 DETROIT 5573014
Ian Beale
Chevy Oil Filter Element, P117, 1949-1954 - Eckler's Early ...Chevy Oil Filter Element, P117, 1949-1954; ... 1949-54 P117 Oil Filter Element $16.99 ea. Add to Wishlist; Description; Applications; Details. Reproduction Of Original;
Ralph Odegard
I would like to thank everyone trying to find the correct oil filter for my HD9B. NAPA 1005 tech bulletin has all the correct dimensions but Wix makes their oil filters Wix 551005 which is 1/2 inch too short in height and too large in diameter to fit canister. I will machine two adapters for top and bottom so a John Deere filters will work.
