Onan ignition. Trouble. |
coggonobrien
Orange Level Access Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1806 |
Posted: 25 Apr 2017 at 6:07pm |
Will the running 616 was parked running at high idle and started stumbling hard so I shut it off. I could get it to rumble but not run and now I can't get any fire. I pulled the ignition box cover and see no motion when I turn the motor over. What actuated the point and how hosed is it
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4641 |
Remove the points and the plunger will come out. What is its condition? Broken or badly worn? The whole sleeve and plunger can be replaced. I would pull the plugs first and make sure your pistons are moving because you may have a broken crank. And loud engine noise before she died?
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3297 |
my whole little ingnition box got loose and moved and shut mine down
macvette
Orange Level Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1656 |
One thing I hope it isn't for your sake, because it happened to me: Engine running at idle, all of a sudden, sounded rough, and heard a grinding sound, so I shut it off. Checked oil, tried to restart, wouldn't restart. Pulled engine out, pulled flywheel off = magnet came loose from flywheel, jammed in between stator and flywheel, and governor module, ripped governor/ignition casing loose, broke mounts, ripped stator loose, twisted wires from stator, and ripped them loose.
Replacement flywheel, stator, etc. Didn't solve issue to charge battery, and now I have put an external alternator on, and now charges battery. I still worry that a magnet could come loose, and it could happen again, but I will deal with it if it ever happens again. |
coggonobrien
Mine was just running rough when I shut it off. I will pull plugs and check for movement. Is it possible for the plunger to brake and fall into the motor?
coggonobrien
I've been considering a mini alternator for mine anyway so I guess we will see.
coggonobrien
I'm beginning to think its the plunger. the adjuster for gap was maxed out as tight as it goes
ac720nut
Orange Level Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
While you have it apart a good time to put electronic ignition on
coggonobrien
I'm going to hold off on electronic way too expensive for a 40 year old engine that'd be a good downpayment on a Briggs swap
AC720Man
I would say it is possible for it to break off enough and fall through. Not likely, but if your box was loose and moved far enough it could. That plunger assembly was the first thing that I replaced on mine. Ran rough, stuttered at times. When I pulled the plunger it was badly worn. Of course she had over 1,000 hrs of run time on it. I have heard about the electronic ignition and would like to find out its cost. Those breaker boxes are a pain in the rear to keep tight and points adjusted. I despise removing the heat shield to get to it.
coggonobrien
well feeling dumb, got it fixed saturday. point and condensor. apparently it was not running as strong as I thought it was before complete failing. now I'm mowing faster with less throttle.
AC720Man
Glad it was an easy fix for you!
