545 |
Mickey
Bronze Level Joined: 12 Apr 2017 Location: Europe Points: 6 |
Posted: 12 Apr 2017 at 7:12pm |
Bought 545 recently with 2900 engine so any advice/info is appreciated since i dont have operators manual. What i am most interested in atm is oil type and quantity for transmission
Dnoym N. S. Can.
Orange Level Access Joined: 03 Oct 2009 Points: 544 |
Allison Transmission2 speed forwardand 1 speed back its ATF3, -If its a little red colored then its ATF3, some people used 10 w oil i would not mix the two do you have a dip stick or not ? dose it look like this? http://files.minnpar.com/partbooks/WHEEL%20LOADER%20MANUALS/FIAT%2DALLIS%20WHEEL%20LOADER%20MANUALS/545%2C545H%20PM%20%2373063928.PDF B:-) Dnoym Edited by Dnoym N. S. Can. - 13 Apr 2017 at 9:02pm |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8150 |
Wow welcome to the forum. Goodluck
Eric B
Orange Level Joined: 09 Feb 2012 Location: British Columbi Points: 888 |
The best success I had with my 745 transmission (just a bigger Allison) was using 30W engine oil giving better pressures as well as improved metal to metal protection. If you're not working the machine hard the thinner oils will do.
Mickey
Hey Dnoym, thanks for the info. I didnt notice dipstick anywhere. Thanks for the link, i already found and dl-ed it, but couldnt find operators manual for free.And yes, it looks like on pic 2, since cab is not mounted yet. I will post some pics soon. Currently i m working on engine so when i m done, i guess i'll have some more questions :-)
Thanks MikeZ Thanks to you too Eric for that info |
Dnoym N. S. Can.
The dip stick is missing
my 1967 545d loader dose not have a dip stick it has two check plug about one in. apart haft way up the tran on the engine side the bottom one is the low level and the top one is the full level check running after warming up and in neutral l . mine also has a tran filter by the engine on the cooler line i have a 1967 545D with a 301 and 2 speed power shift i have a 545D operator manual and in the manual it say lubricate these with SAE 10w oil meeting ATF type c-1 so i think that SAE 10W oil or ATF type C-1 is what they went with in 1967 so i don`t think it need anything special i don`t know if tractor hydraulic would work (i can`t see why not) but the only thing that i did with mine was to take out about 5 gal of oil because they could not find the dip stick to check oil set park brake take the top plug out with drain pan if no oil add oil replace plug and start engine and run at 1000 to 1500 rpm for 1 min. to charge system then take out the bottom plug and add oil as required stop engine this is what mine look like uploads/1493/GetAttachment7.jpg do you have a manual HTH if you need more info let me know let us know how you make out B:-) Dnoym |
Mickey
Mickey
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7997 |
for what it's worth...I was searching net on Allisons and found a place in Texas that was rebuilder.Their info said use 15W40 oil.seems that one of the Ausies chimed in and said that's what they were using.My 78 545B has dexron in it...and it's transferring trans to hyd.Both are using dexron.
AC_Digger
Bronze Level Joined: 24 Apr 2017 Location: Denmark Points: 2 |
re. 545 H
Been the happy owner sins 2002 and it has Dexron in transmission and 10/40 to the engine "it improve the turbo sound :) " I drain it ones and it took about 28 litters ATF oil.
A redline a day keeps the carbon away !
Mickey
After assembling engine (it worked perfectly ) i went to try it out but felt some lack of power. Drained tranny oil and found metal pieces. Took it off, dismantled and found broken parts of the clutch kit
So, i am looking for items 8, 9 & 10 as shown on the picture from parts catalog, new or used. Thanks in advance for any help and info Transmission plate info: Allison division Indianapolis indiana Ser 28117 Part no 6835015 Tt 2220-1 |
Gadget
Bronze Level Joined: 02 Dec 2022 Location: Wisconsin Points: 2 |
Would anyone have any 545 loader manuals they could share?
Jim.ME
Orange Level Joined: 19 Nov 2016 Location: Maine Points: 937 |
If you don't get other responses, eBay appears to have many choices, parts, service and operator's manuals.
AC_Digger
workshop or user manual ?
Gadget
I'm interested in any information I can get. Knowledge is power. But if i had to choose a shop type manual would be first.
