Need Help With 5015 Hydraulic Pump
Rex 11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rex 11 Quote  Post ReplyReply Direct Link To This Post Topic: Need Help With 5015 Hydraulic Pump
    Posted: 15 Mar 2017 at 2:38pm
I'm thinking my 5015 Hydraulic Pump is "shot". Was using it the other day, for pushing snow. It ran pretty decent for about an hour and a half. Then started to work slower, to the point that it would barely lift the blade. I called the local Parts dealer for Deutz Allis he said the hydraulic pump rebuild kit (#72100358) was no longer available. Anyone have any thoughts?
Also, the cable to the tachometer is broken and I understand, that it is NLA as well
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 3:01pm
I have a pump on a parts 5020 if its the same.I'll guarantee it to work as it was working when the crank shaft broke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rex 11 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 3:05pm
Price and pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rex 11 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 1:13am
I'll have to check with my local dealer and see if they are interchangeable. If so, where do you live at, in VA?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 7:26am
I'm 10 miles North of Charlottesville just off US 29.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 8:08am
5015 and 5020 are not the same tractor.
